Posi-Lok Axle Engagement? - JeepForum.com
post #1 of 28 Old 07-24-2012, 07:28 AM Thread Starter
TheSmanman
I'm new to having a Jeep and need to learn a lot. When I purchased my 1989 yj only a few days ago the owner said it had a Posi-Lok Axle Engagement Kit installed. I don't mean to sound like a newbie, but is the Posi-Lok to lock both front wheels so there is no limited slip on the front axle? If so isn't that kind of dangerous when turning when both wheels are turning at the same speed? What is the purpose of the Posi-Lok Axle Engagement system. What situation would it be used for? I'm just not familiar with something like this and have no clue what it's used for or when to use it. I just don't want to break something.
Thank you,
John
TheSmanman is offline
post #2 of 28 Old 07-24-2012, 07:51 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
Basically its gimmick.
Your front axle came from the factory with a vacuum disconnect system. The passenger side axle tube, see that big hunk on it? On that side you don't have a solid axle shaft from the differential all the way to the u-joint. there are two axle shafts in there. In the stock set up, when you shift into 4x4, a vacuum motor would engage an actuator that would connect those two axle shaft together. Here is a picture of the two axle shafts and the collar. This is what you would see if you removed the metal plate in your post,
Pulled out.. below are two separate shafts. I have the collar over them so its hard to tell.
With the collar over the splines on both shafts, they act as one. In the above picture you can see the
collar is not engaged, it only grabbing the splines on the outer shaft.
Someone came up with the idea to replace the stock vacuum actuator with a cable system. Its a very common swap. The cable "posi" systems are finicky and prone to breakage. It is actually not as good as the stock system but many people view it as an upgrade. It is also more expensive and time consuming to install than just fixing the stock system. If it works then leave it alone. Expect it will be hard to engage sometimes and you will have to rock the jeep. So if you want to get into 4x4, you need to shift the t-case and use the cable system.
Poke is offline
post #3 of 28 Old 07-24-2012, 07:58 AM
bogleparsons
Nothing is as cost effective or faster than moving the fork over and repositioning the c-clip to hold it in place.
You will always have a solid axle on that side then. Yes your drive shaft will always spin also.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #4 of 28 Old 07-24-2012, 08:09 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
If you have issues with the cable system... do this.
Poke is offline
post #5 of 28 Old 07-24-2012, 10:51 AM Thread Starter
TheSmanman
Excellent guys and thank you. This was a big help and now I understand it. Now to take it out for a test spin in the trails. (no mud).
Here's a pic of my new toy. What do you guys think?
Poke, I hope you didn't take you front axle apart just to show me the pics you posted above?....LMAO!!
post #6 of 28 Old 07-24-2012, 11:01 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
no problem. you will get a bill in the mail
Poke is offline
post #7 of 28 Old 07-24-2012, 11:05 AM
bogleparsons
Damn I would hate to know his hourly rate.
Nice looking YJ too!
post #8 of 28 Old 07-24-2012, 11:31 AM
YJames90
YJames90's Avatar
Its not a gimmick when you have an Aussie up front. Unlock the posi in tight turns on the trails and your sitting pretty. Try that with the stock set up
My 2.5 to 4.3 swap thread
YJames90 is offline
post #9 of 28 Old 07-24-2012, 12:43 PM
fratis
fratis's Avatar
ive never had an issue with the stock and aussie making turns. strange.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #10 of 28 Old 07-24-2012, 12:51 PM
Michaelgoesrawr
Michaelgoesrawr's Avatar
The only problem I have with mine is that I don't know when it's locked in. I drove an entire road where my girlfriend needed 4x4 on in 2x because I didn't know it wasn't locked. Needless to say I felt pretty cool lol.
Michaelgoesrawr is offline
post #11 of 28 Old 07-24-2012, 02:20 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Here's another billable picture.
Luck Favours The Prepared
Anticanman is offline
post #12 of 28 Old 07-24-2012, 02:57 PM
ssyj94
I ran a posi lock in my old 30 for years after my vacuum stuff took a dump. It worked perfectly for me and I knew it was engaged with just a short pull of the cable. Like james said you can also unlock the one shaft allowing you to turn easier if you have a full time front locker.
You also get a 2wd low range.
My build:
ssyj94 is offline
post #13 of 28 Old 07-24-2012, 08:18 PM
timatoe
timatoe's Avatar
If you're set on doing the Posi skip the name brand big dollar one. Look in the YJ FAQ's and do the home brew one. It works well, I never had a problem with mine but I did end up going to a one piece shaft later so I gave my set up away.
timatoe is offline
post #14 of 28 Old 07-24-2012, 08:49 PM
linusb
Looks like a beautiful rig from here. How much you pay for that jeep If you don't mind saying? Any rust? ...Posi-lock is a simple and functional replacement for vacuum setup. To engage, you need to roll very softly while pulling cable. You should get about a 1/2 inch worth of travel upon that final engagement.
1994 YJ Wrangler, 4.0, AX15, NP231, 35x12.50x15 BFG KM2s, 4" RC lift, 1" lift Boom Shackles, 1" BL, 4.10 gears, 8.8 LSD in rear and D30 Aussie Locker in front, on-board air conversion, Ramsey RE8000 winch.
linusb is offline
post #15 of 28 Old 07-25-2012, 07:45 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
It is also more expensive than replacing the stock system.
More time consuming to install than replacing the stock system.
It is known to be finicky... id you need to roll around to engage it, with the stock system you do not....
simple & functional? Irony? "To engage, you need to roll very softly while pulling cable. You should get about a 1/2 inch worth of travel upon that final engagement." basically its simple and functional as long as you go in reverse, then forward, then reverse, then forward, while pulling on a cable until it "feels" right?
basically, there is nothing better about it than the stock system. The front locker turning point is valid but arguable. This might be the single benefit. I see both sides to that argument.
I know of many first hand... they are all broken.
Poke is offline
yj front axle engagement hurricane99 YJ Wrangler Technical Forum 4 10-24-2011 04:12 PM
Front axle engagement staush YJ Wrangler Technical Forum 7 09-22-2010 07:59 AM
Posi Lock Engagement Question bparsel YJ Wrangler Technical Forum 3 07-07-2009 01:16 AM
Posi-lok engagement problems flame0086 YJ Wrangler Technical Forum 26 02-18-2009 09:13 AM
Posi-Lok axle engagement system JKNIPE2000 YJ Wrangler Technical Forum 2 09-24-2004 04:28 PM
