Posi-Lock, not so posi.. Let me down, again.
#1 | |
Eat, Sleep, Jeep
For the 4th and final time my Posi-lock (home brew) had decided to disengage at the worst possible time. 2 of the last 3 times it was just embarrasing, the first time was just a stuck I could winch myself out of.
Today, right in the middle of a 3 ft deep muddy, baby-poop mucky water crossing it disengaged, got the front two tires mostly out of the muck, but when it disengaged andwent to rear drive only, the rear two tires almost instantly sunk into the muck. The mud was so soft even stopped it continued to sink. Swallowed my 35's completely. I went through this same spot, same hole about 15 times Saturday with no probs. (local playground) Finally got it re-engaged (the axle being off teeth sometimes makes this a PIA when you cant move) but it was way to buried. Had to winch out much to the jeers and laughs of the two Ford rangers I was wheeling with. This week, I'm just going to slide the fork over permenantly and leave it there. Wheelin with unreliable four wheel takes much of the fun out of the day.
#2 |
Join a 4x4 Club
Quit farting with it. Put in TJ shafts.
'93 YJ, '02 GM 4.3 Vortec V6, SOA, dual ARB's, 8.8+D30(w/WarnHubs), 4.88 gears, 35" Trxus M/T's, AX15, 15x7 wheels, NP231+4:1+SYE+2LO, York OBA, Warn M8000, no top or doors Apr-Oct. Member and Web guy: New Mexico 4 Wheelers |
#3 | |
Eat, Sleep, Jeep
Yeah, that's the long term plan! Have a few "real life" priorities for funds right now, Shafts are unfortunately more of a priority-2. ![]() |
#4 | |
Just call me Moose
#5 |
i was having the same problem.... i had to replace my fornt end this weekend and wheile i was doin that i kept that little sleeve that connects the inner shaft to the outter shaft and i put both sleeves in it and when i put my shift motor back on i turned it around... ( shift motor facing the left instead of right)...and bolted it back on..... it has been holdin up fine so far..... try turning the motor around and slide the sleeve over by hand and see if it will line up ok 4 u... also disconnect the vacuum lines to it....
4.0 I6 ARB snorkle 307 -> 411 gear swap lock rite locker on the dana 35 33 x 12.50 Mickey Thompson radial MTZ 4.5" Rubicon Express heavy duty Suspension Lift currie boomerang shackles 8,000 lbs. Winch bikini top tonneau cover pictures?? http://www.cardomain.com/id/ironm98 crazymon01@aol.com |
#6 | |
Poland and PPV!!!!
Talk about embarrasing. My vaccuum system is less than reliable and my 4WD generally wont engage for a while. I was stuck in my parking space on the side of the street the other day. Melted snow had frozen all around me and since my front axle would not engage, I was forced to battle my way out in 2WD. Hyundais and Hondas pulling out left and right around me, and here I am in my Wrangler just spinning tires in place.
Gonna try to lock the collar in place for th etime being until I get a new front or a TJ shaft in there.
-Craig- 95 Rio Grande 07 Ram 1500 SIRA4x4 Club Quote:
#7 |
TrailWorthyFab.com
Telly DSP............Why not just buy a Posi Lock for it? Do away with the vacume. You will never look back. I think the worse thing Jeep ever did is come up with a vacume 4wd. What a joke. Something that can break down under the elements and rubber hose at that. What were they thinking????? I paid the 170$ off of ebay for the posi lock. Pulled my cig lighter (since I'm not a smoker) and that lever bolted right in there. It looks like it was born with it and it only took me about 1 1/2-2 hrs total to do it. Money well spent. I'm not sure why people would try and make their own? The stiffness of the cable on the one you buy is unreal. You can't touch that with a choke cable or whatever they tell you to use to make one for 20$. I feel for you. My 4wd didn't work and I didn't know it I went out with some buds in my V8 powered rig and burried it. It was right then I knew I couldn't take them laughing at me anymore and put the posi lock in and never looked back.
#8 | |
Poland and PPV!!!!
[hi-jack]
I cant justify spending $170 on it. I'd rather swap in the TJ shaft, balance my front shaft, and call it a day. [/hijack]
#9 |
I just used a few washers and called it a day.
Zane Neher 88 YJ. H.O. 4.0L/AW4/twin sticked d300/1 tons/38.5s. |
#10 | |
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards... |
#11 | |
i think it cost me almost 100 to get my drive shaft balanced.. they had to straighten it as well.. ![]()
#12 | |
give it time.......
#13 | |
I'm tired
The Final Salute EVERYBODY is pro-gun, some just don't know it. When an anti-gun person is in trouble, the first thing they do is call 911 and demand that they send somebody with a gun! We've idiot proofed the world... now its full of idiots. - Spiritof76 You will truly be the same today as you will be five years from now, except for two things... ...the people you meet and the books you read. Charles E. Jones |
#14 |
well ur rubber lines should work for a long time i would think.. its the brittle plastic lines that get even more brittle over time thats the problem...
#15 |
Is there any benefit of putting in a tj shaft over just using some washers?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
