Posi-lock Need someone to check this pic
| Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line | DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97- | GR8TOPS Introduces the Exogate HD Tire Carrier |
#1 | |
I am installing a posi-lock 4X4 engagement and the first thing I have to do is cap the vacuum line. I think for my model it is on the intake manifold and I took a pic. COULD SOMEONE PLEASE CHECK TO SEE IF I CAPPED IT RIGHT?
Check out the pic at http://sci.tamucc.edu/~dcooper/jeep/DSC02426.JPG ![]()
#2 |
i have no idea if it is the right line but if it is, then you should be fine
later Zach
1993 YJ with a 4.0 & TF 999 & Np 231 (All to change soon!)
SOLD!!!87 Red YJ with 95 4.0 & NV 3550 & Dana 300 Flipped 3.5 BDS Lift |
#3 | |
H2 Recovery Team Member
RIP: '88 YJ 2.5L Ax-5 NP231 Posi-Loked. Herculined. Optima yellow top. 1" Shackle, 2" BDS. Cragar 397's Aussie front. 92 YJ 4.0L Ax-15 231 5" springs, 1" shackle 31's or 35's depending on my mood |
#4 |
Uncle Paul has spoken...
Pic does not work for me.
My Jeep - Video My Jeep in the Snow 92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com) |
#5 |
Wrong Line. Installed this a few months ago. The line you need to cap is on the passenger side of the engine compartment.
93 YJ 2.5L 5 spd,D35 lockrite,D30 powertrax,4.0L TB,4.0L TB Spacer, Warrior Products rear bumper,Bigrocks offroad front stinger bumper,2.5" ghetto lift,skyjacker hydro's,arb snorkle,31x11.5 super swamper truxus A/T STS on cragar soft 8s,31x10.5 wildcat ext studded on ar 767,hella 500's 1 set fog and 1 set driving,sway bar disco's, extended brake lines,yellow top,CB, body damage to prove I wheel. |
#6 |
Can anyone give me a detailed description of where the vacuum lines are? Pictures would be helpful!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#7 |
bump bump
'99 Cherokee Sport 4x4 TnT Long Arms, Rough Country Shackle Relocation Kit, RE coils and leaf springs from 4.5" kit, ORO U-turn steering, AA SYE, 4.56 Superior gears, OME Shocks, Heavy Duty adjustable track bar, NP231, 33" TrXus MT, Hella headlights w/ IPF Fatboys, Monitor Lizard Front Bumper, Hanson read bumper w/ tyre carrier, AirFlow Snorkel, ARB Air Lockers front & rear, Brown Dog engine mounts, Kilby gas tank skid My CarDomain page |
#8 | |
I think you inplugged the vac line for the EDIT: EVAP gas canister for your fuel system 1st pic: http://laybackman.home.comcast.net/capped.JPG 2nd pic: http://laybackman.home.comcast.net/check_valve.JPG That vac line is unplugged from the back of my intake manifold vacuum source in my pic and goes to that check valve by my battery which supplies vacuum to the whole shift fork system. EDIT the other vac line is for the climate control and if you have another vac line there it is for the cruise control Last edited by laybackman; 05-24-2007 at 07:52 PM.. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
