Posi Lock Engagement Question - JeepForum.com
post #1 of 4 Old 07-06-2009, 08:42 AM Thread Starter
bparsel
2011 JK Wrangler
Did the home made posi lock mod this weekend. Pretty simple and straightforward. I am wondering what tips everyone has found to make engaging it as simple as possible. The issue I'm running into is that I have to put it in Neutral, shift into 4 wheel drive, then I have to put it back into drive and touch the gas to get the Jeep rolling a little and try and catch the splines just right to get the collar over to engage.
Does anybody have any tips to make the process easier? My fear is that I'll get stuck sometime in 2 wheel drive and not be able to spin the front wheel at all to line up the splines and get the 4 wheel drive engaged.
Any tips?
bparsel is offline
post #2 of 4 Old 07-06-2009, 09:01 AM
Louie4
"You pass butter"
Louie4's Avatar
It shouldn't matter if you get stuck because the intermediate shaft will still spin eventually lining up with the splines on the outer shaft. Not sure how to make the shifting easier besides just rolling into it.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #3 of 4 Old 07-06-2009, 10:54 PM
timatoe
timatoe's Avatar
That's how the stock system was designed to work as well. When I still had that set up, I'd shift into 4 hi, then actuate the posi while still moving, never had an issue.
timatoe is offline
post #4 of 4 Old 07-07-2009, 01:16 AM
buckshot500
Even with the real posi-lok cable, you have the same issue. I usually throw it in 4WD as soon as i leave the pavement. Sawing the steering wheel ("S" turns) while at a slow roll helps it slide in.
Originally Posted by 5point1 View Post
Well after I drained the oil, I ran water through the engine to clean out the gunk. (the guy who owned before me obvioulsy didn't know how to maintain the engine).
90YJ98XJ
buckshot500 is offline
Posi-lok engagement problems flame0086 YJ Wrangler Technical Forum 26 02-18-2009 09:13 AM
Posi Lock Question... Pittsbuilder YJ Wrangler Technical Forum 8 01-28-2009 02:36 PM
posi lock question rickr YJ Wrangler Technical Forum 8 03-15-2005 08:12 PM
Posi-Lok axle engagement system JKNIPE2000 YJ Wrangler Technical Forum 2 09-24-2004 04:28 PM
Posi-Lock Question Cobra001 YJ Wrangler Technical Forum 4 09-04-2003 08:21 AM
