#1 | |
Posi Lock
Why does quadratec sell a different posi-lock kit for lifted yj's than stock ones.
For Stock http://www.quadratec.com/products/52435_00.htm For Lifted http://www.quadratec.com/products/52435_01.htm
1991 Land Cruiser HDJ81- 1HD-T Turbo Diesel, Factory F/R Selectable Lockers, Warn M8274, Webasto Thermo 90S 1987 YJ Laredo |
#2 |
Hmmm. Mine came with one so I'm not 100% sure on this, but the cable lenth could be the factor. I wouldn't think 3" would make too much of a difference, my cable has a lot of room if I wanted it stock height or higher or whatnot. But it is a possibility i suppose
#3 |
I would say the cable is longer for the lifted jeep
88yj, incubus off road wheels,32"tsl radial super swampers,2.5" pro comp lift ,kc lights,rock lights,8000lb.mile marker winch,best top bikini top,nutterbypass,lock right locker in the rear,TJ flares,poison spyder rock rails,home made front flat fenders,Skyjacker nitro 8000 shocks,procomp rear bumper,CB.more to come. 92yj,black with flame job.I have now added a 2003 wrangler,2"BB,dick cepek wheels ,trail armor all four corners,33" BFG-AT's.life is good. |
#4 |
ok i was just wondering cause it seemed kinda weird
#5 |
hello. I just bought my jeep and 4x4 does not work. I am almost positive that it is the vacuum system and I emailed the manufacture of posi lok to ask the same question. my jeep is stock except for 1 1/4" shackle lift. I plan on lifting it some day but right now just want my 4x4 to work. they said that the only difference is the cable length. A kit for the lifted jeep will work on a stock jeep also, you will just have more extra cable...
#6 |
ok thx for the info
#7 |
The cable is longer for a lifted Jeep.
Mike 2006 TJ X (Stock - w/ Borla Cat-Back Exhaust) Built a YJ from the ground up: - '04 4.0L (4,000 miles), NV3550 (0 miles), NP231 w/ HD SYE (9,000 miles), 33x12.50x15 Pro-Comp AT's, HP D30/8.8 (4.56 gears), ARB Lockers front and rear w/ compressor, hard/soft tops, full/half doors. -----> Build thread can be read here: http://www.jeepforum.com/forum/f12/yj-build-plan-259306/ |
#8 |
When I bought my Posi-Lok I bought the one with the longer cable ...just in case. I installed the knob under the dash just to the left of the ashtray, then ran the cable through the firewall then over by the back of the air box then down to the front axle to eat up the extra length. Hope that can be of help to you.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
