Popular swap - JeepForum.com
post #1 of 3 Old 04-28-2009, 12:52 PM Thread Starter
bella mia
Popular swap
What is the most poular engine swap. My 2.5 88 is starting to smoke. I can either rebuild it or swap it. Used engines are around $500. What would you advise for the easiest popular swap or rebuild. The 4 doesn't have enough power to lush the jeep very fast on the interstate, so I think rebuilding it is not an option. Have 33's now and thinkinf 35's later. Thanks
bella mia is offline
post #2 of 3 Old 04-28-2009, 01:00 PM
Leans93
She's my density...
Leans93's Avatar
I'd say 4.0L, 350, and 4.3L are the most popular. I swapped in a 4.0L myself. Go to the stick for YJ FAQ and one of the first sections is the engine section and there are lots of good write ups on all of these swaps.
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Originally Posted by Mike Jones
Catch me on the highway or about to tear the mall up.
Leans93 is offline
post #3 of 3 Old 04-28-2009, 01:00 PM
93jeepyj
for 4 cyl guys id say the 92-95 4.0 H.O. swap is the one most are doing. It uses almost all jeep parts so you could have a whole setup by buying a cheep cherokee maybe even for less that rebuilding your 2.5 if you do all the work. Now is the time though, if you think you will eventually want a v8 or even a diesel nows the time. It really all depends on what you want and what you want to spend as well. I'd say the 4.0 swap is probably the cheapest swap and well worth is as the 4.0 is a great motor.
93jeepyj is offline
most popular lift kit ? blockrockin JK Wrangler Technical Forum 41 10-16-2010 07:49 AM
Most popular JK 4DR. lift kit hawkzrno1 JK Wrangler Technical Forum 3 06-23-2009 11:32 AM
Why are D44s so popular? themaniam1 TJ Wrangler Technical Forum 24 05-27-2007 09:18 PM
Popular front axel swap for YJ's? gregg877 YJ Wrangler Technical Forum 2 11-17-2005 04:54 PM
Why are 33s more popular than 32s zband TJ Wrangler Technical Forum 31 08-08-2005 10:13 PM
