popping sound while starting - JeepForum.com
post #1 of 16 Old 04-15-2013, 07:16 AM Thread Starter
bogleparsons
Anyone ever experience a popping sound, from under the hood while starting.
Occasionally mine will POP and not want to start. Damn thing sounds like the intake manifold or something is going to blow apart.
If it's not supposed to move and does use duct tape.
If it's supposed to move and doesn't use WD40
bogleparsons is offline
post #2 of 16 Old 04-15-2013, 08:48 AM
Que89YJ
Backfiring when you are starting? You need to get under the hood and see if you are backfiring.
Que89YJ is offline
post #3 of 16 Old 04-15-2013, 09:02 AM Thread Starter
bogleparsons
well I can only be once place at a time, and it happens when cranking.
The Jeep idles ok I guess even though it's high (about 1500rpm) no backfiring during idle, though it will when you turn it off ONLY after driving.
post #4 of 16 Old 04-15-2013, 09:47 AM
pete1991YJ
Makes me wonder if the timing chain is loose, or the timing is off somehow.
***--- Wrecking Crew member ---***
"I've prolly been around longer than you think"
pete1991YJ is offline
post #5 of 16 Old 04-15-2013, 09:56 AM
Siva283
Turn the key to on. Make sure its in neutral and the brake is set. Use a wire to jump the pins 30 and 86 on the starter relay. Then you can start it from under the hood. I owe Que another thanks for teaching me that trick.
Ask me how I know...
Siva283 is offline
post #6 of 16 Old 04-15-2013, 06:46 PM
Que89YJ
So you do have backfiring then. How many miles on it? For backfiring it is usuall your timing is off or you have carbon build up in the cylinders.
Que89YJ is offline
post #7 of 16 Old 04-15-2013, 06:47 PM
Que89YJ
Timing can be off because the chain is streched. That is why I asked the mileage.
Que89YJ is offline
post #8 of 16 Old 04-16-2013, 05:08 AM Thread Starter
bogleparsons
yes I do have back firing. It started late last year and is sporadic 178k,xxx miles.
post #9 of 16 Old 04-16-2013, 07:58 AM
Que89YJ
You need to listen to it when it is running and see if you can hear the chain slapping against the cover.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #10 of 16 Old 04-16-2013, 08:52 AM Thread Starter
bogleparsons
I think I do hear it slapping against the cover. Man what kind of job am I looking at here?
post #11 of 16 Old 04-16-2013, 09:34 AM
pete1991YJ
Looking at a new timing chain set, with gears and tensioner. Last I checked it was about $70 at Autozone. Probably a couple hours wrenching with a few standard end wrenches and a puller for the balancer. One trick I always do is to make paint marks on everything so I know its all pointing the same way instead of being disturbed.
post #12 of 16 Old 04-16-2013, 09:48 AM
Que89YJ
mark the distributor and rotor too. It's not too bad a job. Just a lot of disasembly to get at it.
Fault codes:
No Start:
Que89YJ is offline
post #13 of 16 Old 04-16-2013, 10:10 AM Thread Starter
bogleparsons
OK I just read a thread on replacing the gears and chain.
I think I can handle it.
wish me luck breaking the news to the wife haha
post #14 of 16 Old 04-16-2013, 10:42 AM
ROTTEN
Get on advanceauto.com
Part # 76070
And part #*TCS 45458
And use promo code
Retmenot124
Your total will be
$48.98 + tax
Pay online and goto the store and pick it all up.
I'm new
ROTTEN is offline
post #15 of 16 Old 04-16-2013, 12:00 PM Thread Starter
bogleparsons
Part # 76070
And use promo code
Retmenot124
Your total will be
$48.98 + tax
Woot Thanks everyone!
