popping in four wheel drive - JeepForum.com
post #1 of 13 Old 01-12-2011, 12:39 PM Thread Starter
yjman92
when ever i run in 4 wheel drive i hear and FEEL a popping thud comming from the front end or transfer case. i know what it sounds like when i turn the wheel on dry pavement and thats not what im hearing. i can drive a staight line in snow and the popping and feel it also. im hoping it is just a bad u joint on the axle shafts or driveshaft, but what im worried is that the chain in the transfer case is skipping teeth or somthing. any body have any experience on this to settle my mind before i have time to switch out u joints?
yjman92 is offline
post #2 of 13 Old 01-12-2011, 12:46 PM
Babcat
I've had the same thing over the past couple of weeks, and came to the same conclusion... until a few days ago. No I belive it is the posi-lock, that is definately where it is coming from, now I just have to bring it in and try to adjust it. If you still have the vac motor it could be the same scenario, motor is not driving the fork far enough. Once I get it fixed I'll let ya know for sure.
Babcat is offline
post #3 of 13 Old 01-12-2011, 12:57 PM
giggityjeeper
you collar is sliding off on the front axle and your 4x4 is popping in and out, it will eventually break something when it pops one of these times....
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #4 of 13 Old 01-12-2011, 01:36 PM
mdreher
Check out this thread. It has tons of great info on this subject(+pics) and an EASY do it yourself fix. I'm really looking forward to doing it to mine. http://www.jeepforum.com/forum/f12/h...ite-up-595515/
mdreher is offline
post #5 of 13 Old 01-12-2011, 05:55 PM
NicksYJ
I wouldnt run 4x4 on snowy roads unless your absolutly have too to get moving i.e. icy as hell or stuck in snow. in 4x4 the front shaft moves slightly slower than the rear for added traction when off roading. But on hard cement it causes much wear n tear on the internals of the t-case that could cause alot of weird noises and problems down the road (pun intended)
NicksYJ is offline
post #6 of 13 Old 01-12-2011, 08:35 PM
Bigboyky
As long as the front tires can slip you're fine to run on the roads in 4x4. Even if it's wet. Dry pavement is a no no! It can and will snap an axle.
1995 4.0l, 5spd., 4:88's, ARB's F/R, 4"RC lift, homebrew bumpers & tire carrier, homebrew gas tank skid, lined inside, Cobra cb, smitty winch, 130w & 55w Hella lights
Envy our past, Fear our future Go Cats!
Take a look at our club
& here on JF
Bigboyky is offline
post #7 of 13 Old 01-12-2011, 08:42 PM
tjtom
Is the popping consistent? Like every 10 seconds it will pop or is it just random pops? If it is consistent popping then your tc chain might have teeth grinded or chipped
tjtom is offline
post #8 of 13 Old 01-12-2011, 10:23 PM Thread Starter
yjman92
it is random popping . so ur saying i might be good on the chain?
yjman92 is offline
post #9 of 13 Old 01-12-2011, 10:24 PM Thread Starter
yjman92
i never run it on dry pavement, when i say snowy road i mean down my street going 10-15 mph in a half a foot of snow
yjman92 is offline
post #10 of 13 Old 01-12-2011, 10:26 PM Thread Starter
yjman92
i know thats what i thought but my fork is permanently locked in place with a c clip, so it has to be something else, its driving me crazy
yjman92 is offline
post #11 of 13 Old 01-13-2011, 03:50 AM
Babcat
How does the "c clip" work? I can get mine to stay engaged by pulling the cable, so it moves maybe 1/8" or less.
Babcat is offline
post #12 of 13 Old 01-16-2011, 08:59 AM
fox9988
sounds like tc chain form here
fox9988 is offline
post #13 of 13 Old 01-16-2011, 09:13 AM
micahtbyrd
disco your front drive shaft, and try driving without it hooked up, this will tell you if its comming from the front axle or front output on your t case,
alsp disco the rear DS, and try driving in 4wd and see if this makes the noise go away this should help you narrow it down to either the f or r axle, t case or trans...also check all the rubber mounts that the trans and t case ride on these could be worn out...u will need to to drop the belly pan to disconect the ds anyway...or get the whole thing on jack stands and sping the tires in to see where the sound is...ideas...good luck.... mine sounded like this for a while and it tuned out it was missing teeth on the rear ring gear...so check that too...
95 YJ wrongler on 36's
micahtbyrd is offline
YJ front drive spinning/posi-lock/no 4 wheel drive bdfletch YJ Wrangler Technical Forum 7 11-09-2009 11:58 PM
popping when engaged in fourwheel drive kojak70 YJ Wrangler Technical Forum 10 08-14-2009 03:49 PM
how do i fix my 4 wheel drive - when in 4wheel drive only one wheel turns c-wag YJ Wrangler Technical Forum 3 06-01-2009 11:45 AM
4 Wheel Low popping out-need help Franchoo TJ Wrangler Technical Forum 7 11-10-2008 10:13 PM
My 4 wheel drive is popping out 94YJRUNNER YJ Wrangler Technical Forum 7 08-02-2007 01:00 PM
