Poor performance and exhaust smell - JeepForum.com
post #1 of 5 Old 02-13-2002, 11:14 AM Thread Starter
92jeeper
My 92 2.5 fuel injected jeep sometimes does not want to go above 60mph no matter how much I press the gas. Also, there is always an exhaust smell. I have recently changed the Cat. converter, muffler, fuel pump and filter, Transmission and clutch. This problem has remained constant thoughout all these changes. Any suggestions???
92jeeper is offline
post #2 of 5 Old 02-13-2002, 01:24 PM
Islander89
I am not a trained mechanic but if you smell exhaust you have a leak somewhere and you are probably losing back pressure which could effect engine performance. I had a metal pipe-to-rubber hose seperation on a pipe that went from the catalytic converter back to the engine. My engine is a 4.2L so your layout might be different. It was very smelly and the car would not run smoothly until the clamp was replaced. You may also want to have the exhaust manifold checked.
Islander89 is offline
post #3 of 5 Old 02-18-2002, 11:03 AM Thread Starter
92jeeper
Thanks Islander89. After doing a little research my problem seems to be related to the exhaust manifold, possible leak or crack just as you mentioned. Thanks again!
92jeeper is offline
post #4 of 5 Old 02-18-2002, 12:41 PM
jeepinarkansas
1982 CJ8
heres another thought...I had a similar problem on my 95. Turned out to be a exhaust bolt right above the manifold. I sheared off the bolt head during a deep water crossing, i think, and that caused a smell and a loss of compression in my engine. Maybe that will help. Good Luck.
JAke
1982 Jeep Scrambler
5.3 Vortec
SOA on 37s
jeepinarkansas is offline
post #5 of 5 Old 02-18-2002, 04:18 PM Thread Starter
92jeeper
Actually, when I had my muffler and cat. replaced, they pointed out a missing bolt on the exhaust manifold. I fixed that and it sounds a lot better but still has the smell. I've noticed on this website some reference to cracked exhaust manifolds. I'm thinking at this point I should have this checked out. I'll let you know what I find.
92jeeper is offline
no power, poor performance ronfezz YJ Wrangler Technical Forum 14 02-23-2010 08:56 PM
New exhaust but poor performance?!? hollinger101 YJ Wrangler Technical Forum 13 03-07-2009 12:20 PM
poor idle performance rick_chicago YJ Wrangler Technical Forum 13 09-24-2005 09:16 AM
anyone else have poor performance in rain? el guapo YJ Wrangler Technical Forum 8 12-19-2004 04:03 PM
poor performance archie YJ Wrangler Technical Forum 6 06-02-2004 07:42 PM
