Poor mans lift question??? - JeepForum.com
post #1 of 19 Old 07-21-2010, 11:55 AM Thread Starter
ShowStopper
Wanting a small lift to accomodate 31's. My stock leafs are currently under the axle. Has anyone ever just relocated them to the top of the axle for a slight height increase? pro's cons of doing so? thanks in advance.
ShowStopper is offline
post #2 of 19 Old 07-21-2010, 11:59 AM
vadslram
SOA isn't a slight lift or cheap....as far as I know.
I'm pretty sure the cheapest lift would be new shackles.
vadslram is offline
post #3 of 19 Old 07-21-2010, 12:00 PM
I8AHUMR
It's a common thing to do...
SOA Conversion
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #4 of 19 Old 07-21-2010, 12:02 PM
TheNewbie
It's called a SOA (spring over axel) and it's waaay more than you want fro 31's and it's not cheap. It will clear 35's without a sweat though. It's about 5.5" of lift.
Now if you want a cheap lift just to clear some 31's I'd go with some homemade shackles. Just get some steel, cut to length and drill some holes for the shackle bolts.
1995 YJ 2.5 - 4 RC lift - 1" MML - 33's - flat fenders front - TJ flares rear -Raptor lined exterior - Herc'd interior - DIY front bumper & winch plate - 136 amp alternator mod - 4.0 TB swap
I've got a shotgun, a rifle and a four wheel drive...
TheNewbie is offline
post #5 of 19 Old 07-21-2010, 12:03 PM
giggityjeeper
doing it right now.....
not fun, not easy, NOT CHEAP.... to do it semi right anyhow.. I am even cutting some corners for the time being like no highsteer and using a pitman arm, but other things you WILL have to get...
I would just buy some new 2-4 inch lift springs, baring in mind a 4 will require a Tcase drop or pitman arm and probably slip yoke Elimator
take a look at the last couple pages here, or anywhere ther are tons of threads on a SOA anywhere on the net or here..
http://www.jeepforum.com/forum/f12/h...-jeep-1050879/
Started with some rust repairs ended in a SOA...
family roll bar swap/upgrade..
1990 YJ. SOA, OME 36R 3.5" lift springs, OME 5/8 greasable shackles, OTT high steer, Custom cage, team Rush, Posi, 33 TSL swampers
giggityjeeper is offline
post #6 of 19 Old 07-21-2010, 12:04 PM
Old4X
1990 CJ7
If you just want to clear 31's, just put on a set of TJ flares and trim the tub in the rear. Back the steering stops out to stop tire rub and you are set, no need to spend many 100's of bucks lifting and such.
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #7 of 19 Old 07-21-2010, 12:22 PM
Destr0
If all you want to do is clear 31s then TJ flares or remove your flares completely.
For a budget lift go with bastard packs, I am adding S-10 Blazer leafs to my YJ on all four corners, total cost will be less than $150 and should get me up to about 3" of lift.
Tube fenders front and lots of trimming in the back will get me to 35s, although the 35s will have to wait until I find an 8.8.
Destr0 is offline
post #8 of 19 Old 07-21-2010, 12:56 PM
DoctorPhate
XJ Cherokee
31s, get shackles. You could also trim your fenders a bit if you're sagging.
DoctorPhate is offline
post #9 of 19 Old 07-21-2010, 01:01 PM
ImpactFabWorks
This is the first place everyone should look before posting...... also the search function is your friend.
=====YJ Frequently Asked Questions (FAQ) and Write Ups, Find your answers here=====
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #10 of 19 Old 07-21-2010, 01:58 PM Thread Starter
ShowStopper
Geez, the posting police have nothing better to do.....
Anyways, thanks for all the feedback. I was just tossing that idea around, At first glance without really diving in too deep, I figured I'd only be gaining the thickness of the axle tube. I see now it would be alot more than that.
post #11 of 19 Old 07-21-2010, 02:12 PM
ImpactFabWorks
sorry for posting a link that would have answered your questions
post #12 of 19 Old 07-21-2010, 02:46 PM Thread Starter
ShowStopper
Sorry for being a lil on edge, it's just get frustrating..... Everytime somebody asks a simple question, someone else tells them they should search the forums or comb thru all the frequently asked questions, then, and only then can they ask a question..........
We're all here because we love these vehicles. I come here because there is always someone else thats been there and done that. Until I asked this question I had no idea what the hell "SOA" even stood for... Sometimes we newbys do search, but want something extra or a newer answer than whats presented in a post from 2006.....
post #13 of 19 Old 07-21-2010, 03:05 PM
DoctorPhate
XJ Cherokee
Its fine. nobody will fault you for it
post #14 of 19 Old 07-21-2010, 04:05 PM
xjoverkill
If you do this then you will actually lower your YJ...
98 XJ 5 speed
xjoverkill is offline
post #15 of 19 Old 07-21-2010, 09:15 PM
ImpactFabWorks
If you would have clicked the FAQ link and scrolled down to the suspension section, You have had the answer to what it is and how it's done. Also you would have learned the term SOA. I don't care what year the thread is from it would have answered your question
Poor College looking for some cheap lift roblee TJ Wrangler Technical Forum 8 05-02-2008 05:25 AM
Poor boy lift kit linexrandy TJ Wrangler Technical Forum 32 02-21-2008 03:13 PM
How do I go about a poor mans lift.... BrokeJoke YJ Wrangler Technical Forum 11 06-19-2007 12:55 PM
New Poor Mans Rear Bumper aviatorguy YJ Wrangler Technical Forum 21 06-09-2006 12:46 PM
which lift for a poor college student??? powerman330 TJ Wrangler Technical Forum 21 03-26-2005 08:45 PM
