Poor heat - JeepForum.com
post #1 of 3 Old 09-08-2008, 08:10 AM Thread Starter
sheamus
1990 MJ Comanche
Poor heat
My heat seems to work but only when I'm moving, even when I am moving the heat is barely there. Also there seems to be no difference between hi and lo, it blows the same no matter what. Is my problem the blower motor?
1990 Comanche Eliminator
4.0L
D30/8.8
Disc Brakes front and rear
2" Budget Boost, Grand Cherokee front coils, AAL
Rubi Wheels
sheamus is offline
post #2 of 3 Old 09-08-2008, 08:12 AM
jakemary
1977 CJ7
pull the blower motor out and check it on the workbench and look for leaves stuck inside there.
jakemary is offline
post #3 of 3 Old 09-08-2008, 10:53 AM
timatoe
timatoe's Avatar
I would bet it's a bad blower motor. You should also read through some of THESE threads from the FAQ and heater stuff, lots of good info in there.
timatoe is offline
Wrangler has poor heat and runs cool RednekWrangler YJ Wrangler Technical Forum 50 10-24-2013 02:55 PM
Poor Heat: what am I missing? richla TJ Wrangler Technical Forum 17 01-06-2010 03:00 PM
poor heat from heater core marko686 TJ Wrangler Technical Forum 5 09-20-2008 10:19 PM
Sad day, what to do with my poor YJ? hokiehoo YJ Wrangler Technical Forum 18 05-17-2007 08:50 AM
Poor Heat In My '97 Tj. Swedejeeper TJ Wrangler Technical Forum 8 12-23-2005 06:49 PM
