Polyurethane Bushings Install - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Polyurethane Bushings Install
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep JK Wrangler 3" Suspension Lift Kits $439.99 deliJeep XJ Cherokee Ulitmate Sliders now available!
Unread 04-17-2007, 11:27 AM   #1
Skeezer
Has anyone changed over to poly bushings, If so did it make a difference ? The rubber under my YJ is pretty well shot so i'm going to try poly bushings. It seems like alot of work replacing every bushing but It's gotta be done.
Thanks
2005 Rubicon
Skeezer is offline   Reply With Quote
Unread 04-17-2007, 11:51 AM   #2
ovrlnd
I have the prothane kit on mine and love it. way better ride and even after 5 years they still look brand new.
"We'll get out of this disaster in time for the next one"
"I'm done recomboobulating the energy-mo-tron"
88 YJ, 350/350 Chevy, Twin Stick Dana 300 with JB 32 spline rear output, 6.5" lift, Front Scout II Dana 44 w/Yukon 4340 shafts, trac loc, 4.27's, Warn Premium Hubs, flipped YJ Tie Rod, Ford F150 front calipers, Rear Scout II Dana 44 w/Alloy 4340 shafts, HD RPT retainer plates, 4.27's True trac, Steeltech Disc brakes, Cage upgrade, B&M Prostick Shifter, Custom Fabbed tire, gas, jack carrier, 3/8 angle rear bumper, clevis's all around, old & reliable rep8000 winch. Flood lights. loud stereo. 35x12.50 swampers and a bunch of other stuff
ovrlnd is offline   Reply With Quote
Unread 04-17-2007, 11:58 AM   #3
mean90yj
Yota Recovery Specialist
mean90yj's Avatar
i don't think it would be too big of a deal, if you have a hi-lift jack it makes it easier to jack up the body, i have never done it so i don't know from personal experience but some mention it helps to have an extra hand.
'90 I6 258 w/ Weber 32-36 Carb.
32" BF M/T's with cragar rims
5" BDS springs, MORE greasable shackles, XJ driveshaft, AA SYE kit, RE SS brake lines. Bilstein 5150's, 255/70 valving all around, 14" travel in front, 10" in rear.
~Enjoy>>> http://youtube.com/watch?v=nQCIXoBqpc0
JF MOTO>>>>"Ban a tard...save a life" <<<contributed by leftlanetruckin
OMNIPOTENCE...gotta get me some of that
mean90yj is offline   Reply With Quote
Unread 04-17-2007, 12:11 PM   #4
ovrlnd
loosen all the bolts a little but only remove one bolt at a time. you'll have to lift the body a little but not that much. if all your body bolts are in good shape it should take you an hour or two.
Unread 04-17-2007, 03:35 PM   #5
Skeezer
This may be a stupid question but where do I jack from when lifting the body ?
2005 Rubicon
Unread 04-17-2007, 03:42 PM   #6
Angelous
1987 YJ Wrangler
I just finished installing a prothane 1" body lift on my YJ about 30 minutes ago. I used a floor jack and and a 4 x4 to spread out all the weight. You will want to soak all your bolts about a week before hand. You have 11 total. 1 in the very front under the radiator. 3 along each side. 2 Up around the gas tank( I didnt see these until the very last minute). And finally 2 at the rear by the bumper. The instructions are good. Just loosen all the bolts at once and then lift one side at a time. I found a big prybar to be very very helpful. You will need a breaker bar(unless you have air tools) A 5/8 socket, a 6" extension and a 3/4" socket.
"There is no hole to deep, or mountain to steep, for the driver of this Jeep!"
87 YJ - 2.5 - TJ Flare Swap - Rubicon's - no track bars -
Angelous is offline   Reply With Quote
