Please verify this is correct - Alternator Wiring Set-up - JeepForum.com
post #1 of 3 Old 02-29-2012, 09:40 AM Thread Starter
medicjz
I plan on putting in a CS144 and want to run #2 wire from what other posts are indicating. My question is, when I redo the wiring I want to do the following...
1) Remove current wire from (+) on back of alternator to solenoid with all the other wires below the original battery tray ( I believe this is the starter solenoid).
2) Run #2 wire from (+) on alternator to (+) battery terminal (w/ 150amp fuse in-line)
3) Retain current wire from (+) battery terminal to solenoid located below battery tray
4) Ensure that the Red wire that goes into the two-prong connector on the alternator is also hooked to (+) terminal on alternator
5) Reconnect (-) battery terminal, start and verify voltage with meter
6) Wash hands and have a Rum & Coke
I would like to thank JeepHammer for having the below original wiring diagram for me to butcher with my not so fabulous image skills. I included it to provide a picture of my understanding of what needs to be done from the other posts I found in the search, I mainly want to make sure I am understanding those posts, because I couldn't find pictures of the wiring in any of them.
Also, I plan on putting a switch panel in as I add accessories, and saw in a post that an easy solution for tripping relays from those switches, that a wiring possibility would be cat5 cable due to the low amps used to switch relays and the ability to have the wiring neatly organized with multiple strands in the one cable. Has anyone done this and is the individual strand from each pair capable of being used for this ( I'm not sure what wire size it is or what amperage it can utilize without being an issue)
Thanks in advance for the help.
medicjz is offline
post #2 of 3 Old 02-29-2012, 10:17 AM
Que89YJ
You have the wiring setup correct for the alternator. Yes, you can use gound switch for relay control. The control side relay can be wired with 20 guage. I am not sure what the guage is in the cat 5 but I just setup a Neon PDC for KIG to ground switch 8 relays and add 5 in independant fuses.
Que89YJ is offline
post #3 of 3 Old 02-29-2012, 07:20 PM Thread Starter
medicjz
Thank you for the confirmation
medicjz is offline
alternator , cs144 , wiring
Alternator Wiring jrwilkinsonjr YJ Wrangler Technical Forum 4 09-18-2011 10:53 PM
Alternator Wiring demesauce YJ Wrangler Technical Forum 3 08-20-2009 08:16 PM
Help verify setup is correct smitkev2 YJ Wrangler Technical Forum 3 03-04-2008 12:13 PM
Correct battery / alternator voltage 92Islander YJ Wrangler Technical Forum 6 02-24-2008 04:49 PM
Does this fog light wiring look correct to you guys? MCTampa YJ Wrangler Technical Forum 10 07-13-2006 12:57 AM
