Please judge my rust - JeepForum.com
post #1 of 23 Old 04-28-2013, 02:00 PM Thread Starter
rippinlt
I know the ultimate test is getting under there with a screw driver and poking around but that isn't currently an option.
Is this rust to worry about?
rippinlt is offline
post #2 of 23 Old 04-28-2013, 02:19 PM
gunshw301
I have seen worse, but the pics you provided aren't areas that rust the worst....so it could get uglier. Look around the shackle points, behind and around the exhaust, inner side of the frame. Good thing is someone has gotten the skid plate bolts loose at some point.
F/S Dana 35, 4:10, open make an offer, local pick up only, will not ship. 3-8-13
gunshw301 is offline
post #3 of 23 Old 04-28-2013, 02:28 PM
Kdeome
You call that rust?!
Looks fine to me.
Kdeome is offline
post #4 of 23 Old 04-28-2013, 04:35 PM
DirtKar
I pledge allegiance.
DirtKar's Avatar
Looks fine to me.
I saw a response like this one coming. You will likely get opinions from you call that rust? from the East coast to my Holy Moly Rustman! from the West.
I guess it's up to you to decide if the structural integrity of the metal is compromised and go from there. Good luck
Luck Favours The Prepared
YJOTM JULY 2014
DirtKar is offline
post #5 of 23 Old 04-28-2013, 05:39 PM Thread Starter
rippinlt
So what methods can be taken to avoid the rust getting any worse? I know people take their tubs off, coat their entire frames with sealant and are happy forever but is there a localized method? something like sand down the bad areas and paint them with some rhinoline-like spray.
rippinlt is offline
post #6 of 23 Old 04-28-2013, 05:58 PM
Que89YJ
Que89YJ is offline
post #7 of 23 Old 04-29-2013, 06:20 AM
rambo3489
I would say mine was as bad if not worse. Check the drivers side frame up front too where the steering box bolts up to. Mine was rotted bad there. Another common place is under the rear shock towers. But the tub looks fine which mine was not I had a big hole on the drivers side. I would say your alright. But will tell you working on things is a real PITA.
If you don't see any real problem areas I would clean it up and get some rust stopping primer on it. You don't have to take the tub off. It's better. I did it. But that's the route I wanted to go. Spot checking it all and getting some rust inhibitive primer or POR-15 on it should do the trick.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #8 of 23 Old 04-29-2013, 06:29 AM
Kdeome
I would take the tub off, sand/wire brush the surface rust, treat and rinoline the frame.
Kdeome is offline
post #9 of 23 Old 04-29-2013, 07:16 AM
responder
X2.
From what I see in most of the pictures, that is mostly surface rust. It depends how far you want to go with the build will determine how much work you are going to do.
For that type of rust a descaler works great! Good luck.
responder is offline
post #10 of 23 Old 04-29-2013, 07:55 AM
Jeepsr4me
From what I see, you have rust in spots that I normally dont have issues with. SO you will more than likely have it in the bad spots REAL BAD. Shock shaft are gone, brake lines gone, i see the frame having some bad times...
Jeepsr4me is online now
post #11 of 23 Old 04-29-2013, 02:17 PM
Rproject
1987 YJ Wrangler
I too find the rust on the shock shafts to be interesting. Has this vehicle sat for a long time? If it was mine, I'd replace the shocks rather quickly. As for the frame, you're not keying in on the traditionally nasty areas: Just in front of the rear tires where the frame bends to go to the front. Front/rear shackle mount points. Those are the areas I'd look to see if they're trashed. If so, there are kits available. If they're fine, grind, prime, paint with POR-15.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #12 of 23 Old 04-29-2013, 06:35 PM
Luuca
Typical /f12 Hooligan
Luuca's Avatar
91 YJ "Alice" 4.0L, AX-15, NP 231 Flange, Adams Driveshafts F/R, 2.5" OME 36Rs, 5/8" /f12 Booms, 32" Yoko ATs, 4.10 D30/35 AutoLockers F/R
YJOTM Sept. 2017
05 LJ Rubicon "Ghost"
Luuca is offline
post #13 of 23 Old 04-29-2013, 07:17 PM Thread Starter
rippinlt
unfortunately this is no longer my rust. I was headed up tomorrow to purchase the jeep but it sold today before i could get there. I keep losing the ones I plan on buying. one of these days... well thanks for the rust lesson anyhow!
rippinlt is offline
post #14 of 23 Old 04-29-2013, 07:58 PM
Luuca
Luuca's Avatar
Jeeps choose their owners. Yours is out there. Be patient and prepared.
YJOTM Sept. 2017
Luuca is offline
post #15 of 23 Old 04-29-2013, 08:13 PM
Xenephobe375
Besides the fact that it's sold, that's not bad at all for rust. That could easily be sanded down/taken off and repainted.
Xenephobe375 is offline
