Please identify this part! - Page 2 - JeepForum.com
post #16 of 26 Old 06-17-2012, 09:38 PM
Desert_Rampage
1991 XJ Cherokee
No problem. Good luck. -Ian-
"Chainsaws can dismantle anything... Or you can just take it apart by removing screws until it opens, but what fun is that? "--Motoman22
Desert_Rampage is offline
post #17 of 26 Old 06-17-2012, 09:48 PM
exige05
No that is the actual piece that engages ur high beams, same exact situation happened to me and it took three hands just to get that little piece in then snap the plastic cover on the steering column. It rests against a metal rod that looks like an L. Look on the inside on the plastic cover and u should see a mark from where it use to slide. That's what helped me figure out proper placement
exige05 is offline
post #18 of 26 Old 06-17-2012, 10:31 PM
GunHo198
Yep. Check YouTube on rebuilding a steering column and how to take it apart. You will probably have to take your lock cylinder out and remove the outter collar to put it back in. I think I might have a spare that I can take better pics of.
Here's pice 1. This is off of a tilt column.
The plastic piece goes inside the rear part just behind the turn signal lever. The most forward section will have to slide forward so you can remove the rear plastic section. There are 3 torx screws holding the fist section on. Again youll have to remove your lock cylinder, and your tilt wheel lever if you have one. The turn signal lever is fine to leave on.
Pic 2 shows sliding the rear cover off.
Pic 3 shows where the piece is supposed to sit. You should put a little grease on it so it stays put when you slide it all back together.
While getting all this apart isn't really that hard. It's best to watch the YouTube videos so that you know how to take the steering wheel apart. You will need some special tools as the main retaining plate is under spring pressure. You can get one at most autoparts stores. Most Chevy columns of the same year have the same parts as our Jeeps. I believe they were standard Saginaw parts.
As for removal of your lock cylinder it depends on your year. Early models were held in by a small torx screw. 94's like mine have a detent pin.
94 Jeep Wrangler 4.0 with AX-15 Trans.
4" Procomp Lift, 3" body lift, 35" BFG Tires, Ford 9" Rearend with NASCAR Detroit Locker, Super 30 Front with ARB, Onboard Air, Dual Optima Batteries,Warn M8274 Winch, and Bushwacker Fender Flares.
GunHo198 is offline
post #19 of 26 Old 06-17-2012, 10:55 PM
GunHo198
Also there is a small electric clip that goes in by the cylinder. If you break it when you remove it, it's no big deal. It's for that annoying key buzzer. I've broken everyone I've done. LOL A Chiltons or Haynes book might have some info to help you along as well. You don't need to pull the whole column. You can do it in your Jeep. Just take your time and don't lose any screws.
GunHo198 is offline
post #20 of 26 Old 06-18-2012, 09:25 AM Thread Starter
punchesdfw
Mine looks a bit different than yours. But, that's obviously where it goes.
Thanks for your help!
punchesdfw is offline
post #21 of 26 Old 06-18-2012, 04:50 PM
Lushaholic
Originally Posted by punchesdfw View Post
I looked, but don't see where it may have come form. I'll look further tomorrow when I have better light. Thanks!
This picture has the part you are looking for. It looks different because it is properly seated. I came across this part several months ago when trying to fix my horn. I put it in the wrong way (thats what she said) and had to take it out and put it in correctly.
Lushaholic is offline
post #22 of 26 Old 06-19-2012, 03:37 PM Thread Starter
punchesdfw
Here was the culprit. $37!
post #23 of 26 Old 06-19-2012, 06:33 PM
Nafpu
2012 KK Liberty
Originally Posted by Desert_Rampage View Post
That's what she said! (I had to!)
Oh lord, if SHE'S in deeper than that, we got ourselves a problem...
95 YJ, gone...
80 CJ7, gone...
12 KK, still here...
Nafpu is offline
post #24 of 26 Old 06-19-2012, 08:39 PM
GunHo198
Thats that dohicky that connects your turn signal lever to the multifunction switch. It's held on by 1 screw..
GunHo198 is offline
post #25 of 26 Old 06-19-2012, 11:06 PM
Opihi59
from here it gets rough
Opihi59's Avatar
Don't feel too bad, these do break. Here's another current thread with the same broken part. Not sure yet of the resolution to his broken part, but you did confirm it is available at the dealership.
http://www.jeepforum.com/forum/f12/l...-part-1380585/
Forgot the link earlier, sorry. There may be useful information in here for you.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Last edited by Opihi59; 06-20-2012 at 11:38 AM. Reason: Duh, forgot to post the link.
Opihi59 is offline
post #26 of 26 Old 06-20-2012, 12:50 AM
GunHo198
You can get them at the junkyard out of Cherokees and most chevy's off the 90's vehicles. Most of those columns use the same parts. Same with the multifunction switch as those are really pricey!
GunHo198 is offline
steering column , turn signal , windshield wiper switch
Can't Identify this part. bigbossd1030 YJ Wrangler Technical Forum 6 04-16-2011 10:30 AM
Please Identify This Part jkl TJ Wrangler Technical Forum 7 04-04-2011 10:59 AM
Please identify this part nummy TJ Wrangler Technical Forum 3 01-09-2011 04:41 PM
Identify This Part rrasco TJ Wrangler Technical Forum 2 11-24-2010 01:26 PM
help identify this part... wranglerboy YJ Wrangler Technical Forum 9 02-14-2010 09:21 PM
