Please identify this part! - JeepForum.com
post #1 of 26 Old 06-17-2012, 07:00 PM Thread Starter
punchesdfw
Saturday I was driving my Daughter's '95 Wrangler. I used the turn signal and something snapped. Then, the turn signal lever just flopped around and didn't do anything. I removed the steering wheel, turn signal switch and wiper switch. They all look fine. But this part fell out. It is black plastic and is approximately 3/4" wide by 1 3/4" long. It must be some kind of a stop or actuator, but I don't know where it goes. Any ideas?
punchesdfw is offline
post #2 of 26 Old 06-17-2012, 07:09 PM
Desert_Rampage
1991 XJ Cherokee
I have a steering column apart right now, for mine. I don't remember ever seeing THAT.
"Chainsaws can dismantle anything... Or you can just take it apart by removing screws until it opens, but what fun is that? "--Motoman22
Desert_Rampage is offline
post #3 of 26 Old 06-17-2012, 07:25 PM Thread Starter
punchesdfw
I'm sure that it broke off from somewhere. But, I can't find where!
post #4 of 26 Old 06-17-2012, 07:29 PM
Desert_Rampage
1991 XJ Cherokee
Oh nvm. It sits below the turn signal switch inside the column..... I'll try for a pic...
post #5 of 26 Old 06-17-2012, 07:32 PM
Desert_Rampage
1991 XJ Cherokee
This?
Sent from my EVO 4G using JeepForum
post #6 of 26 Old 06-17-2012, 07:39 PM
garin3
I think it's the piece that goes behind the turn signal lever to push on the rod that switches your headlights to bright.
2007 jk rubicon unlimited, rescue green, rugged ridge bumpers, 9000# superwinch, 3" procomp lift and 1990 yj 4.2L, weber carb, tfi ignition, nuttered, bushwacker flares, 4" suspension lift, 33" cooper stt tires , Grey soft top, tinted windows, bikini top and red body
garin3 is offline
post #7 of 26 Old 06-17-2012, 07:53 PM Thread Starter
punchesdfw
Originally Posted by Desert_Rampage View Post
This?
I can't see what part you are talking about.
post #8 of 26 Old 06-17-2012, 07:57 PM
Desert_Rampage
1991 XJ Cherokee
That whole piece. It's two parts. Does that pic compare to what you see in your column?
post #9 of 26 Old 06-17-2012, 08:01 PM
Desert_Rampage
1991 XJ Cherokee
Where I'm pointing is where the lever attaches to (and pivots on)
post #10 of 26 Old 06-17-2012, 08:03 PM Thread Starter
punchesdfw
I'm in deeper than that. Are you saying that you think it may be part of the plastic housing?
post #11 of 26 Old 06-17-2012, 08:04 PM Thread Starter
punchesdfw
I understand now. I'll go take a look. Thanks!
post #12 of 26 Old 06-17-2012, 08:05 PM
Desert_Rampage
1991 XJ Cherokee
Yes it may be part of that housing.
post #13 of 26 Old 06-17-2012, 08:16 PM
Desert_Rampage
1991 XJ Cherokee
That's what she said! (I had to!)
post #14 of 26 Old 06-17-2012, 08:25 PM
timatoe
timatoe's Avatar
Look through these links and you'll know about all you can of what's in the column....
http://www.chevyasylum.com/column/tiltcol.html
http://www.epiccomputer.com/dale/jee...tilt/tilt.html
http://www.bc4x4.com/tech/2009/jeep-steering/
timatoe is offline
post #15 of 26 Old 06-17-2012, 08:29 PM Thread Starter
punchesdfw
I looked, but don't see where it may have come form. I'll look further tomorrow when I have better light. Thanks!
steering column , turn signal , windshield wiper switch
Can't Identify this part. bigbossd1030 YJ Wrangler Technical Forum 6 04-16-2011 09:30 AM
Please Identify This Part jkl TJ Wrangler Technical Forum 7 04-04-2011 09:59 AM
Please identify this part nummy TJ Wrangler Technical Forum 3 01-09-2011 03:41 PM
Identify This Part rrasco TJ Wrangler Technical Forum 2 11-24-2010 12:26 PM
help identify this part... wranglerboy YJ Wrangler Technical Forum 9 02-14-2010 08:21 PM
