PLEASE HELP!!! NP231 transfer case install - JeepForum.com
post #1 of 27 Old 09-23-2013, 08:43 PM Thread Starter
Jeepsterchick15
I'm an extremely stubborn young lady that likes to do my own work. Including removing and installing an np231 transfer case. I got the new one in, then realized I misplaced 3 of the bolts that mount the case to the transmission. I can't find anywhere online what size these bolts are... Wasted a free evening going back and forth to the parts store only to fail every single time. Can some one please enlighten me????
Jeepsterchick15 is offline
post #2 of 27 Old 09-23-2013, 08:55 PM
superj
Take one of the others to Lowe's or oriellys and go through the racks till you get a match.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #3 of 27 Old 09-23-2013, 08:59 PM
kloppk
You lost the nuts or did you loose the studs?
They are metric....
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #4 of 27 Old 09-23-2013, 09:09 PM Thread Starter
Jeepsterchick15
Thanks for quick response. There was only three studs in the one I purchased used on eBay... Therefore I can't take them out :/ any other suggestions? I don't see why it's so hard to look up online?! I have the nuts from the other studs from my old t case. Feeling frustrated 😣
post #5 of 27 Old 09-23-2013, 09:11 PM Thread Starter
Jeepsterchick15
I took a nut to the parts store, but that bolt that fit the but is not big enough for the remaining holes... I would think if I bought a brand new t case it would come with new mounting bolts...which is why I "thought" it would be so easy to find online?
post #6 of 27 Old 09-23-2013, 09:18 PM
jeep108
Use the search bar and type in 'np231 mounting studs'
Find the"YJ of the month" contest in the stickies and participate!
Eph 6:13 -Therefore put on the full armor of God, so that when the day of evil comes, you may be able to stand your ground,
Originally Posted by Opihi59 View Post
Welcome to the forum.
If you are a mechanical neophyte and have to repetitively intone the mantra of "lefty loosey," are a mouth breather and only own a hammer, it will be more of a challenge.
jeep108 is offline
post #7 of 27 Old 09-23-2013, 09:26 PM
mudsweatNgearz
1987 YJ Wrangler
Take two of the nuts and screw em onto a stud. Use two wrenches and tighten the nuts against each other (simultaneously unscrewing the bottom one and tightening the other). When they are locked together REAL tight you should be able to unscrew the stud. Take that to Ace hardware and have them match the studs and nuts.
I wondered why the baseball kept getting bigger and bigger....then it hit me!
mudsweatNgearz is offline
post #8 of 27 Old 09-23-2013, 09:32 PM
JeepinJeremy
threads should be M10x1.5 on the tcase flange. You'll probably need then 40-50 mm long if you want to just use a bolt
JeepinJeremy is offline
post #9 of 27 Old 09-23-2013, 09:38 PM Thread Starter
Jeepsterchick15
I would prefer just a bolt since I am an amateur mechanic �� I will try to find those bolts...wondering if they're usually in stock. Just ready to drive my jeep again!
post #10 of 27 Old 09-23-2013, 09:39 PM
JeepinJeremy
Ace Hardware stocks them all day long
post #11 of 27 Old 09-23-2013, 09:40 PM Thread Starter
Jeepsterchick15
Thank you! I will give that a try tomorrow!
post #12 of 27 Old 09-23-2013, 09:42 PM
JeepinJeremy
If by chance you have an older 231j threads will be 3/8x16. You never posted what year yj your working on or what year 231 case you swapping in.
post #13 of 27 Old 09-23-2013, 09:56 PM Thread Starter
Jeepsterchick15
It's a 1995 YJ, and both are the 231Js... Sorry I'm still learning haha! The bolt I brought home from the parts store (that fit the nut) was a 3/8-24... But is too small??
post #14 of 27 Old 09-23-2013, 10:25 PM
imstillatwork
Studs often have two different threads on the ends, one thread for going into aluminum, a different thread pitch for the nut.
So you really need to know the thread pitch of the end that s in the case already.
imstillatwork is offline
post #15 of 27 Old 09-24-2013, 05:06 AM
jeep108
I forgot I have a np249 boat anchor sitting in my garage and I bet the studs are he same. I'll try to get one out.
jeep108 is offline
