Please help with my serpentine belt - JeepForum.com
post #1 of 13 Old 04-15-2010, 10:01 PM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
I can't find a good diagram of the way my belt should go back on.
Jeep: 95' - I6 - no air.
I think I have it correct but want to make sure. Here is a diagram of the way I have it now.
Is this correct? If not, can anyone post a picture of the way it should be?
Thanks!
-John-
johnboy68 is offline
post #2 of 13 Old 04-15-2010, 10:52 PM
Roadyy
no it's not correct according to the book. The elt should come from under the alt down to the harmonic ballancer then under the water pump as it comes over the power sterring then under the tension pulley to the alt. Hope this helps. I dont have a way to copy the drawing, sorry hope the wording helps.
Roadyy is offline
post #3 of 13 Old 04-15-2010, 10:53 PM
Roadyy
instead of the loop to the water pump being between the alt and harm bal, it should loo to the water pump between the harm bal and the pwr sterring pmp. This drawing doesn't show the tension pully below the pwr sterring pmp. sorry if it doesn't help
Roadyy is offline
post #4 of 13 Old 04-16-2010, 05:20 AM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
What book? I have the Chilton's book and the diagram it has doesn't match my setup.
-John-
post #5 of 13 Old 04-16-2010, 05:36 AM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
I found this thread in the TJ area that has a diagram out of a book that matches the way I have mine setup.
Here is the link:
http://www.jeepforum.com/forum/f9/he...emoved-842691/
I'm feeling better about the way mine is now. Can anyone confirm?
-John-
post #6 of 13 Old 04-16-2010, 09:44 AM
jaycal3
Here is what I found for a Serpentine belt routing-1990-95 2.5L and 4.0L engines without A/C ...
93 YJ, 6 cyl,3.5" BDS,1" Prothane BL,1/2" booms, 33" Mickey Thompson MTZ on MT Beadlocks.
Do your part for Leukemia research - help find a cure.
KCCO
jaycal3 is offline
post #7 of 13 Old 04-16-2010, 02:57 PM
ajs96
Thanks!
The diagram you made represents that you have a later model power steering setup from the 97+ models.
That is the proper way to run the belt on those models, i put a 98 power steering pump and bracket on my 93 and that is the correct route IF you have the later model pump setup
The factory setup on the 95 should use the powersteering pump pulley itself as the adjustable tensioner and does not have a dedicated tensioner/idler pulley underneath it.
ajs96 is offline
post #8 of 13 Old 04-16-2010, 07:23 PM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
Thanks. I defendant have the dedicated tensioner pulley under my power steering pump. After seeing the diagram from the TJ forum that matches my setup I started thinking I may have a "newer" setup.
I'll stick with it.
-John-
post #9 of 13 Old 04-16-2010, 07:57 PM
I8AHUMR
10char.....
93 YJ, 4.0, 4.5" suspension, 33x13.5 Pitbull Rockers, Custom scratch and dent job...
05 WK, 5.7 Hemi, Quadra-Drive II
I8AHUMR is offline
post #10 of 13 Old 04-16-2010, 08:08 PM
Roadyy
I was going by the book like jaycal 3 was saying for 90- 95. I didnt realize you were using newer setup.
Roadyy is offline
post #11 of 13 Old 04-16-2010, 08:25 PM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
I don't think that's the right diagram:
-John-
post #12 of 13 Old 04-16-2010, 09:14 PM
Roadyy
I just went and looked at your build thread and before you took the motor out there is a pic of the belt setup like you posted johnboy. you have it setup rite with that diagram that you drew.
Roadyy is offline
post #13 of 13 Old 04-17-2010, 10:11 AM Thread Starter
johnboy68
HIP2BSQR
johnboy68's Avatar
You ROCK
Why didn't I think of that? You would think after taking the time to take pictures of the rebuild process I would have thought to go back and look at them
-John-
Serpentine Belt kyhangdog TJ Wrangler Technical Forum 4 03-07-2009 01:29 PM
Serpentine Belt E_ROCK YJ Wrangler Technical Forum 5 07-17-2003 09:41 AM
Serpentine Belt zombieCat TJ Wrangler Technical Forum 2 07-02-2003 08:36 AM
Serpentine belt won't fit DennisBlevins TJ Wrangler Technical Forum 8 06-11-2003 08:15 AM
Serpentine Belt Hero TJ Wrangler Technical Forum 2 06-04-2003 09:10 PM
