please help ive never seen a carb before - JeepForum.com
post #1 of 5 Old 05-19-2012, 01:42 PM Thread Starter
jeepistool
1997 XJ Cherokee
My brother bought an 89 islander 4.2 with some kinda ford carb on it. Now to get it running we spray starting fluid in the hole twice then she runs fine even starts good after shes warm. i cant see gas entering the hole like i was told i should. does this mean its bad? can anyone tell me exactly which carb to buy because none of the oem stuff remains, vac lines, huge goofy air cleaner i really like the aftermarket 12" air filter and the manual choke i have now and was lookin for an ederbrock or holly thank you for reading
jeepistool is offline
post #2 of 5 Old 05-19-2012, 02:21 PM
Jax89Jeeper
If you infact have a motorcraft 2100/2150 you already have a great carb.... It may just need a rebuild and retune. These are reliable, great for off camber trail driving, and the easiest the deal with carb for a newbie. Easy to rebuild and tune. Typical rebuild kit is $20 or so. Buying a new carb would be a waste of cash.
Post some pics, it will be easy to tell what you have.
Jax89Jeeper is offline
post #3 of 5 Old 05-19-2012, 02:33 PM
NH2112
A manual choke is probably the least effective of all kinds, if it was me I'd scrounge up the parts to convert it to automatic. The need for starting fluid could be due to the manual choke (with an automatic choke you pump once or twice to set the choke and give a good shot of gas), bad accelerator pump, incorrect idle mixture, incorrect idle speed setting, etc. My recommendation would be to have it tuned or do it yourself - assuming it's not dirty inside it can be done in about 5 minutes with a vacuum gauge once the engine is warmed up - and see how it goes from there.
Phil
'90 YJ w/4.2l & 4.0l head, Weber carb, 5-speed, 4" RC lift, 33x10.5x15 BFG MT KM2s.
NH2112 is offline
post #4 of 5 Old 05-19-2012, 03:57 PM
40dog
pictures of carb please
Keep your nose to the wind and your eye upon the skyline
40dog is offline
post #5 of 5 Old 05-28-2012, 03:10 AM Thread Starter
jeepistool
1997 XJ Cherokee
Thank you Sirs im having a hard time getting a camera it has numbers 1.06 stamped in a circle if that helps. also it seems much larger than the 2100/2150 or anything that should be on it
carb , carburetor , YJ
Weber Carb vs. Stand. Carb 89 YJ Beast89 YJ Wrangler Technical Forum 10 05-20-2012 10:38 AM
Carb guys just said to me motorcraft carb are not good for the jeep. spawnofsatan YJ Wrangler Technical Forum 24 04-09-2011 07:46 AM
to re-carb or not to re-carb, that is the question dougimes YJ Wrangler Technical Forum 5 04-24-2010 07:30 AM
carb adjustment on 88 6cyl carb onlyoneromeo YJ Wrangler Technical Forum 5 04-04-2009 05:56 PM
carb bobbert350 YJ Wrangler Technical Forum 1 06-24-2006 09:00 AM
