Please help identify this unplugged harness 1990 YJ - JeepForum.com
 2Likes
  • 1 Post By mike134
  • 1 Post By mike134
post #1 of 14 Old 10-09-2017, 01:27 PM Thread Starter
jboyte
I was looking under the hood because my 1990 YJ when I found this part of the wiring harness that is not attached to anything. Please see the two images and help me figure out where it is suppose to be plugged in.
Thank you for your help!
jim
Screen Shot 2017-10-09 at 3.25.17 PM.jpg   Screen Shot 2017-10-09 at 3.25.07 PM.jpg
jboyte is offline
post #2 of 14 Old 10-10-2017, 06:57 PM
JeepJJ
Power steering
JeepJJ is offline
post #3 of 14 Old 10-11-2017, 09:09 AM
bharris68
Daily Driver
JJ is correct - there should be a switch/sensor on the bottom of your power steering hose into which that plugs. It tells the PCM that you've steered hard enough at idle (or close to it) that you're risking a stall. Thus - the PCM bumps up idle to prevent it.
bharris68 is offline
post #4 of 14 Old 10-11-2017, 10:10 AM
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Correct, except the PS sensor was only used on the 2.5L engine. So that connector isn't needed. All the harnesses are generic, that's why it's there.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline
post #5 of 14 Old 10-11-2017, 06:32 PM
Labhound
It looks like it hasn't been connected to anything.
Labhound is offline
post #6 of 14 Old 10-11-2017, 06:37 PM
Mr.B
Mr.B's Avatar
It wouldn't be, the 4.2L doesn't have the sensor it would be plugged into.
Ham license:
Everyone is Welcome
Mr.B is offline
post #7 of 14 Old 10-11-2017, 07:58 PM
JeepJJ
He has a 2.5 but still may not have power steering. Mine doesn't.
JeepJJ is offline
post #8 of 14 Old 10-12-2017, 07:52 AM
Mr.B
Mr.B's Avatar
According to his profile, the OP has a 4.2L. But you're right, mine didn't have PS either, until I put it in.
Ham license:
Everyone is Welcome
Mr.B is offline
post #9 of 14 Old 10-12-2017, 11:52 AM
mike134
OoooooooooOOOooOOoOOOOOOh.....
Perhaps extend this into the cab and add a hand switch to it to increase idle speed for winching!
Tophog1 likes this.
mike134 is offline
post #10 of 14 Old 10-12-2017, 01:49 PM
Mr.B
Mr.B's Avatar
Ooorrr, put a bicycle shift lever in the cab to incrementally raise the idle.
Ham license:
Everyone is Welcome
Mr.B is offline
post #11 of 14 Old 10-12-2017, 09:49 PM
mike134
You expect me to actuate a lever like a cave man, when I could be pushing a button?
If I offroaded more, it would be a bit more useful. Perhaps I should install one and then offroad more.
Mr.B likes this.
mike134 is offline
post #12 of 14 Old 10-12-2017, 11:25 PM
Tophog1
It's a JEEP!
Offroad it!
USN vet, 1976-80
Moderator, Nevada Shooters
1993 YJ
1990 YJ
Tophog1 is offline
post #13 of 14 Old 10-13-2017, 07:29 AM
Mr.B
Mr.B's Avatar
The PS sensor doesn't raise the idle that much. And I think it's just a short burst.
Ham license:
Everyone is Welcome
Mr.B is offline
post #14 of 14 Old 10-13-2017, 09:50 AM
mike134
Originally Posted by Tophog1 View Post
It's a JEEP!
Offroad it!
Ohio kind of sucks.
You can tell because everyone that lives here walks around looking like a tourist. They all wear "CLE" T-shirts with slogans saying how great clevleand is.
mike134 is offline
