please help get my dana 35 c clips out - JeepForum.com
post #1 of 4 Old 03-06-2002, 05:25 PM Thread Starter
sadler207j
I am trying to remove my axels and I cant figure out how to get the c clips off . its on jacks no tires or drums. am i missing somthing. ps this is for my 93 zj . I am asking here because I check these topics for my 94 yj. and the yj owners are way more helpfull then the zj owners. most zj dont understand the whole jeep thing.
sadler207j is offline
post #2 of 4 Old 03-06-2002, 05:41 PM
GREGDOG95YJ
GREGDOG95YJ's Avatar
YOU WILL NEED TO REMOVE THE DIFF COVER PUSH IN ON THE AXLE AND THEN REMOVE THE C-CLIP.
HOPE THIS HELPS
Jason Gregory
95 yj Rio Grande 2.5L
31" BFG MUDS, 1"BL,2" homemade spring lift, 150W KC'S, KN Filter, both air restricters gone, track bars gone, quick discos, & high flow cat
"just like all addicts my need to satisfy my addiction far exceeds my wallet!!"
GREGDOG95YJ is offline
post #3 of 4 Old 03-06-2002, 08:59 PM
osburn
osburn's Avatar
He meant to say, remove the diff cover, remove the pin holding the cross shaft in place, remove the cross shaft, then push the axle shafts in.
Matt Osburn
Score 1032
osburn is offline
post #4 of 4 Old 03-06-2002, 09:26 PM Thread Starter
sadler207j
THANKS JEEPERS. I WAS TOLD ABOUT PUSHING THE AXELS IN TO GET THE C-CLIP OUT BY MY AUTO PARTS MAN, BUT THAT DOES NOT SEEM POSSIBLE WITH OUT REMOVEING THE CROSS SHAFT THAT 2 OF THE 4 SPIDERS ARE ON. THAT SEEMS TO BE THE MISSING STEP . THANK YOU FOR YOUR REPLY, I AM VERY GREATFUL. P.S AS I SUSPECTED I RECEIVED NO REPLYS ON THE ZJ FORUM.
C-clips GreatWhiteYJ YJ Wrangler Technical Forum 3 01-25-2008 12:28 PM
cant get c-clips off rebuiltyj TJ Wrangler Technical Forum 2 11-30-2007 02:09 PM
HELP getting my C clips off axle conor.davis YJ Wrangler Technical Forum 3 02-07-2007 09:23 PM
How Do I Get The C-Clips Off An 8.8 Rearend? samsammy23 TJ Wrangler Technical Forum 1 04-04-2004 06:11 PM
C-clips???? Jash927 TJ Wrangler Technical Forum 3 03-16-2004 09:22 AM
