Please Help: 4wd problem, not vacuum related - JeepForum.com
post #1 of 3 Old 01-20-2002, 06:22 PM Thread Starter
bobznew
I know this problem is not vacuum-related, because I've got a Posi-Lok installed, and it does a good job of connecting the two front half-axles.
I often times have difficulty getting the jeep into 4wd. I have to shift the transfer case back and forth several times before it will engage, and even then it will disengage if in a bind.
Is this a t-case problem, a driveshaft problem, or something else?
Any help would be appreciated.
'97 ZJ, 4.0L, Gibson Cat-back system, Daily Driver
'95 YJ, 4.0L, 3.5" BDS suspension lift, Boomerang Shackles, BDS Shocks, 33x12.50 TSL's, Lock-Rite in rear, No-Slip up front, Posi-lok, Warn XD9000i winch, and a ton of dried Mississippi mud!
bobznew is offline
post #2 of 3 Old 01-21-2002, 01:23 PM Thread Starter
bobznew
btt
bobznew is offline
post #3 of 3 Old 01-21-2002, 01:37 PM
AJ
t-case probably
AJ is offline
Brake Related Electrical Problem Lostnthought560 YJ Wrangler Technical Forum 2 05-30-2009 07:30 PM
cruise control issue, vacuum related? trmn8r TJ Wrangler Technical Forum 4 04-22-2009 06:08 PM
bogging/cut out problem related to cat? Exhale YJ Wrangler Technical Forum 2 03-05-2007 10:52 PM
starter problem. electrical related. Big-n-Broke-YJ YJ Wrangler Technical Forum 7 11-21-2006 05:36 AM
Blinker and Hazard Problem - Related? MarkF TJ Wrangler Technical Forum 4 08-10-2006 01:26 PM
