Please Help!!!!! - JeepForum.com
post #1 of 5 Old 12-01-2013, 09:51 PM Thread Starter
kowen
Please Help!!!!!
So I endoed my jeep a month ago. It was on its top for about 30 mins. it wasn't running until I figured out the fuel pump fuse was knock.use back in it started running but now it runs very sluggish and has no power. I changed the oil, cleaned the spark plugs and am unsure what I should do next to get the motor running right. any opions on what I should do would be very appreciated. please help and thank you in advance!
kowen is offline
post #2 of 5 Old 12-01-2013, 10:49 PM
jred
I want to hear the story
Did you drain and replace all the fluids before you tried to start it? Did you CLEAN the plugs or REPLACE them?
jred is offline
post #3 of 5 Old 12-02-2013, 06:10 AM
Que89YJ
Check codes and post what you get:
http://www.jeepforum.com/forum/f12/h...codes-1257145/
Clean the throttlebody and chances are you have an issue with a cracked exhaust manifold throwing off the O2 sensor.
X2 what is the story?
Que89YJ is offline
post #4 of 5 Old 12-02-2013, 06:20 AM
Old4X
1990 CJ7
Fill in your profile.
You running a diesel?
418 miles on 19 gallons of gas. Can't beat the BBD !
Old4X is offline
post #5 of 5 Old 12-02-2013, 07:12 AM
Siva283
Listen to Que he will get you there.
Now how about that story.
Ask me how I know...
Siva283 is offline
