Please help - JeepForum.com
post #1 of 11 Old 05-13-2013, 10:02 AM Thread Starter
Forg3dlife
Please help
Let me start off by saying thank you I have read a lot of great stuff on hear over the years and hope you guys can point me in the right direction.
my 88 yj occasionally has no power, to be more specific, sometimes when I cut it off and go to turn it back on with key switched in on position there is nothing, no lights, nothing! other times it will turn over weakly as if the battery is dead, the starter will even click, ill leave and an hour or to later it fires rite up. any ideas?
its howell fuel injected
and just replaced the starter relay
thanks in advance
Forg3dlife is offline
post #2 of 11 Old 05-13-2013, 10:32 AM
4x4JB
Could be a weak battery. Drive to one of the parts stores that does free checks on your battery and alternator. They can tell you right off what is good and bad. Don't even have to take anything out of the Jeep.
4x4JB is offline
post #3 of 11 Old 05-13-2013, 11:03 AM
Jeepsr4me
check grounds and battery terminals for corrosion.
Jeepsr4me is offline
post #4 of 11 Old 05-13-2013, 11:07 AM
Que89YJ
x100 with Jeepsr4me. You have a bad connection on the battery. Clean and or replace all the battery terminal wires and the other side where they connect. Very very common issue.
Que89YJ is offline
post #5 of 11 Old 05-13-2013, 11:34 AM
mcoulter57
That was happening to me because I couldn't get a tight enough connection on the neg terminal, so I replaced the connectors now it works great
mcoulter57 is offline
post #6 of 11 Old 05-13-2013, 11:46 AM Thread Starter
Forg3dlife
battery checked out, ill check the grounds today and keep you guys posted thanks!
post #7 of 11 Old 05-13-2013, 01:26 PM
Rproject
1987 YJ Wrangler
If everything checks out, you may want to start looking at the ICM. They can be seriously flaky before they decide to go on a permanent vacation.
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #8 of 11 Old 05-13-2013, 02:23 PM Thread Starter
Forg3dlife
just checked icm glad that wasn't it just replaced that sucker last summer with an msd 6
post #9 of 11 Old 05-13-2013, 02:24 PM Thread Starter
Forg3dlife
when its losing power itsnot even turning over even the cd player resets itself
post #10 of 11 Old 05-13-2013, 03:00 PM Thread Starter
Forg3dlife
well guys I cleaned up the major gound (from batt to block) and it seems to have cleared everything up much appreciated.
post #11 of 11 Old 05-13-2013, 03:02 PM
MukYJ
MukYJ's Avatar
Bad ground strikes again! Glad you got it fixed.
~/Garth - 1993 Wrangler S 2.5
{ }|||||||{ } "MukYJ"
He's right, as soon as you remove the trackbar the fuel rail will arc on the battery, killing you and all the kittens in a ten mile radius.
MukYJ is offline
