Pleas help with "crunching" sound coming from front wheel area - JeepForum.com
post #1 of 10 Old 02-28-2009, 07:31 AM Thread Starter
Jeeeeeeeeeeeeep
Yesterday I heard a crunching sound coming from front end, didn't think anything of it as it sounded just like driving on some ice, crunching or popping sound seems to be coming from front wheel, but then I kept noticing it so I knew I have a problem. It only makes the sound when turning sharp in either direction. I gave it a quick visual and didn't see anything obvious, too cold to work on it last night. Do you guys have any ideas on what to look for? Maybe a wheel bearing? Thank you for the help.
1991 Jeep Wrangler 2.5L, 5 speed
2003 SVT Cobra Supercharged 32V 4.6L, 6 speed
Jeeeeeeeeeeeeep is offline
post #2 of 10 Old 02-28-2009, 07:36 AM
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
Need some more specs on your rig in your profile. Are you stock, lifted, bigger tires???
My advise would be to remove the wheel in question and check things over. Grab the wheel before removal and test this:
hold at 3 & 9 O'clock position and try to move the tire back and forth. If she moves, you are looking at steering problem/tie rods etc. Prolly not your issue.
Hold at 6 & 12 position and repeat. If you have wheel bearing/hub issues, this is where you will see movement. Not this can also show ball joint issues but that would have made a different sound/feeling than just a crunch.
Give your U joint a once over as well.
Also, if you are lifted/bigger tires, you could be rubbing the inner tire on the frame/leaf spring at full turn.
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline
post #3 of 10 Old 02-28-2009, 07:46 AM Thread Starter
Jeeeeeeeeeeeeep
sorry Rusty, My rig is pretty stock with no sway bar or trac bars, slightly bigger tires, maybe 30" tall or so. This problem has just occurred. I am heating up the garage right now to do some tests.
post #4 of 10 Old 02-28-2009, 07:49 AM
rustywrangler
Sounds good. Hopefully it is not the hub. I hate hub work.
post #5 of 10 Old 02-28-2009, 07:52 AM Thread Starter
Jeeeeeeeeeeeeep
So how will I know if it is the hub?
post #6 of 10 Old 02-28-2009, 07:55 AM
rustywrangler
If you are having noises in the cabin, you will know the hub is bad by the feel. It should not be loose at all. The instructions above that I listed will show a bad hub.
post #7 of 10 Old 02-28-2009, 07:58 AM Thread Starter
Jeeeeeeeeeeeeep
OK thanks. It crunches pretty bad but only when turning. I'm going to the garage now, I'll keep you posted.
post #8 of 10 Old 02-28-2009, 08:35 AM Thread Starter
Jeeeeeeeeeeeeep
*Update* Well I got it fixed. Jacked the front up... Nothing loose, tires did not wiggle or anything. Took it for a drive, everything was normal...continued driving for a minute, the dreaded crunch was back when turning. Drove back home. Did some searching around and finally came to the conclusion that my leaf springs had some ice in them and were rubbing together, Gave them a good spray of the PB and life is GOOOOD!!
post #9 of 10 Old 02-28-2009, 09:02 AM
griffsyj
haha thats awesome..i wish i had that kinda luck when i heard a bad noise. mines always something drastic like an axle shaft comming out of the axle!
griffsyj is offline
post #10 of 10 Old 02-28-2009, 08:39 PM Thread Starter
Jeeeeeeeeeeeeep
Ha ha, same here, I always prepare for the worst...I got lucky this time!
"whirring" coming from rear wheel ben8jam TJ Wrangler Technical Forum 4 06-04-2008 11:22 AM
Squeeking/ chirping coming from front right wheel area?? Goondock TJ Wrangler Technical Forum 11 01-24-2008 05:53 PM
"pingy" sound coming from engine joebbaseball TJ Wrangler Technical Forum 9 09-21-2007 02:39 PM
Crunching Sound From Rear Driver's Side Wheel imbezol TJ Wrangler Technical Forum 3 07-30-2007 11:15 PM
hit a bump..now my front left wheel area has a squeaking coming from it sk80soarus YJ Wrangler Technical Forum 6 09-04-2006 10:11 PM
