Quantcast Playing in the garage this morning (truss) - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Playing in the garage this morning (truss)
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 06-05-2007, 01:47 PM   #1
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
After recently yapping with Martin & finding out his Jeep doesn't fit "my mold" I figured I would make him another truss since the one I shipped to him didn't quite fit as I expected it would. No big deal though - another fellow Jeeper will make use of it (Dale/Weekender1969).
Anyway, I made at least some progress this morning before needing to get ready for my evening shift at work.
Drilling the spring plate truss holes was easy enough after I cut the plates to the new specs. I start with a relatively small bit & work my way up from there.
Looks to be ~34.5" between center to center of the outer ubolt holes I'd say Martin.
Here she sits, almost ready for the Miller (not Millertime, MillerMatic MIG )
I still gotta finish the center support brace, drill a few holes in that, & triple check everything before welding all the pieces together. Hopefully I'll finish it tomorrow.
Joe Dillard is offline   Reply With Quote
Old 06-05-2007, 01:51 PM   #2
GrimJeeper91
Is this for a D30?
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline   Reply With Quote
Old 06-05-2007, 05:39 PM   #3
Joe Dillard
Originally Posted by GrimJeeper91
Is this for a D30?
It's for a HPD30 set-up SOA.
Old 06-06-2007, 02:13 AM   #4
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
joe, you are the man!
its actually for a high pinion dana 30, sprung over, that is 1" wider than everyone else's dana 30.....
hopefully i will have better luck with this one....damn jeeps!
cheers again mate
martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee....
1998 Range Rover 4.6 HSE
2000 4.7 4WD WJ with a rebuilt motor.
4.3/700r4/new frame buildup (YJ)....
http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/
Years to gain the hands on experience, and offer it freely.
Minutes to gain the knowledge from the internet, and quote it just as freely.
Choose wisely!
leftlanetruckin is offline   Reply With Quote
Old 06-06-2007, 02:44 AM   #5
Joe Dillard
Thanks Martin. I'm hopefull that this one does the trick.
I work the eve shift again tomorrow - so during the AM I should be able to finish the support brace cutting and drilling. Then after that's done, fire-up the MIG and start tact welding things and run some beads. Piece of cake.
Old 06-06-2007, 02:56 AM   #6
leftlanetruckin
XJ on 37's
i wish roll cages with compound angle notches were as easy.....
found out the hard way that the b pillar on dales rig is metric! so had a little "finessing" to do.....
need to go back to school and relearn mathematics me thinks.....
http://www.jeepforum.com/forum/showthread.php?t=324622
Choose wisely!
Old 06-06-2007, 03:02 AM   #7
Joe Dillard
The roll cage stuff is new to me since I have zero experiance with a bender & notching.
Good to hear it was your head banging the wall & not mine.
Old 06-06-2007, 11:28 AM   #8
leftlanetruckin
XJ on 37's
mine and dales....
apparently he had ever messed with a notcher either....and maybe never will again!
my poor old notcher, it has a hard life.....gets used hard, then left in the corner all oily,forgotten, until we abuse it again.
then start cursing it...
martin
Choose wisely!
Old 06-06-2007, 03:12 PM   #9
Joe Dillard
O/T: But....funny thing happened first thing today. I went to move my bench grinder, which I haven't done in a few weeks, and low & behold, look what I found under it. Beer $$. $14 bucks worth.
BOT: Fired up the MillerMatic this morning & here's the progress. Not much left to do except finish the support brace, which should happen tomorrow. Aligning things without a jig took longer than I expected....oh well.
Old 06-06-2007, 04:30 PM   #10
richmond1273
keep the pics coming i would like to see the finished product and what it looks like installed
http://community.webshots.com/user/richmond1273
1995 Wrangler 4.0 AX15 NP231 D30 & 35 4.10 gears
3" Rough Country suspension 33x12.50 Mastercraft MT
2007 JK 3.8 42RLE Auto NV241 D30 & D44 4.10 gears
richmond1273 is offline   Reply With Quote
Old 06-06-2007, 08:21 PM   #11
doug_1994
Joe, your welds look purdy.
Doug
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline   Reply With Quote
Old 06-07-2007, 12:40 AM   #12
rbn1357
Originally Posted by doug_1994
Joe, you look purdy.
Doug
I see a proposal coming soon!
rbn1357 is offline   Reply With Quote
Old 06-07-2007, 01:52 AM   #13
Joe Dillard
The pics above are of the 6th revision. It will be going on Martins Jeep.
Here's a pic of revision #4 IIRC. It is almost finished in the pic below.
I'm starting to work on revision #7 for the HPD30, and also working on revision #1 for an 8.8.
Here's a pic of one while I was playing on Sledge Hammer.
Old 06-07-2007, 02:01 AM   #14
Joe Dillard
Thanks Doug, I'm slowly improving.
rbn1357, shame on you for thinking those thoughts.
Old 06-07-2007, 01:23 PM   #15
atomicmoose
Just call me Moose
atomicmoose's Avatar
Joe, I know that you design these for SOA applications but I have a question...
Do you think this would work with a u-bolt flip kit?
atomicmoose is offline   Reply With Quote
Glock Forum
