Play in Steering Wheel - JeepForum.com
post #1 of 14 Old 04-27-2011, 10:59 PM Thread Starter
poeser
hey guys i got a 89 YJ there's alot of play in the steering wheel, does any one know whats wrong with it? an how much would it cost to fit?
thanks yall!
poeser is offline
post #2 of 14 Old 04-27-2011, 11:12 PM
spawn12348
Up and down movement or just left to right ??
spawn12348 is offline
post #3 of 14 Old 04-27-2011, 11:15 PM
mylightsrsquare
if its left to right play it is probably the little u joints in the shaft that goes from the wheel to the steering gear, or really bad tie rod end
1988 yj. 4.2l with a Weber and an ax15 swapped in
mylightsrsquare is offline
post #4 of 14 Old 04-27-2011, 11:16 PM
moonshinefuel
The question is a little vague. Play when you turn side to side? Or it has play in tilt steering? Or there is kind of a clunking play in the say.. Pulling up and pushing down in a manner of words..
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #5 of 14 Old 04-27-2011, 11:17 PM
89yjsahara258
Try this thread http://www.jeepforum.com/forum/f12/s...riteup-498155/
It talks about some gear adjustments and its free and simple to try first.
89yjsahara258 is offline
post #6 of 14 Old 04-27-2011, 11:20 PM
klrstew
+2 on that one. Gatta 92 with a jittery steering wheel too.
A lot of my rattle is in the steering tube thats coming out of the
firewall in the engine compartment. Is that a hard fix?
I heard people shimming that, or is that just a temporary fix?
Also, I checked out that 4x4xplore.com write up on straightening
the steering wheel out. Basically loosen up two nuts and turn the
turn buckle either way until the steering wheel is straight.
Sounds easy enough. But, I have this bracket thing that has
a piece of steel running through the middle of the pinched
sleeves that prevents me from turning it. Seems like it's doing a great job
from even letting me turn it. lol. Do I just give that
few wacks with a mallet and move it down enough to clear it,
so I can turn it?
klrstew is offline
post #7 of 14 Old 04-27-2011, 11:24 PM Thread Starter
poeser
sorry guys,
they play is in left to right movement i could turn the wheel a little before it engages theres some dead space in bettwen
poeser is offline
post #8 of 14 Old 04-27-2011, 11:28 PM
spawn12348
It could be the lower steering bearing , I had to replace mine when I purchased my jeep I backed out and heard the bearings falling out there is a great right up on how to check and change the bearing , I used it and saved myself a lot of money from a shifty garage
post #9 of 14 Old 04-27-2011, 11:32 PM
klrstew
Thanks, I'm going to try that one tomorrow.
klrstew is offline
post #10 of 14 Old 04-27-2011, 11:33 PM
mylightsrsquare
i still say check the u joints first, grab the shaft and turn it to see if there is any play. thats whats wrong with mine at least =p
post #11 of 14 Old 04-27-2011, 11:40 PM
klrstew
Gotta link on that write up spawn? I think that's one of my problems.
klrstew is offline
post #12 of 14 Old 04-27-2011, 11:50 PM
spawn12348
here you go
http://www.jeepforum.com/forum/f12/r...-my-yj-609628/
also scroll down and it links you to another with lots of pictures
hope this helps
post #13 of 14 Old 04-28-2011, 11:31 AM
klrstew
thanks spawn!
so I can turn it?
klrstew is offline
post #14 of 14 Old 04-30-2011, 11:19 AM Thread Starter
poeser
thanks for the help yall!
poeser is offline
Steering got loose... Play in steering wheel. AnonymousD YJ Wrangler Technical Forum 4 11-27-2010 08:22 AM
Play in the steering wheel Goldneye YJ Wrangler Technical Forum 4 06-19-2010 01:36 PM
Steering wheel play chiefkp TJ Wrangler Technical Forum 2 08-14-2007 07:21 PM
Play in steering wheel JamesLouis YJ Wrangler Technical Forum 0 10-13-2006 12:23 AM
Steering Wheel Play!!! blacktj TJ Wrangler Technical Forum 5 01-07-2004 07:23 AM
