Plastic weld - JeepForum.com
post #1 of 5 Old 10-19-2007, 10:12 AM Thread Starter
x91b20
Plastic weld
Hi guys....I have a 91yj with 1/4in cracks on both sides of the plastic gas tank. I was looking through the threads about using a plastic welder to repair. Anyone have any experience with this repair? Also, does anyone know where I can go get this done without have to purchase a plastic welder? THANKS!!
x91b20 is offline
post #2 of 5 Old 10-19-2007, 11:39 AM
91yjwrangler6
if you really want to save this tank i would go get that stuff called pc plastic. i've never used it on a gas tank but it works pretty good. every time i have seen people try to use those plastic welders it never worked out right. Just go to any hardware store and they should have it.
91 yj, 4.0, AX15, SOA, 8.8 rear, 4.88 gears, 2.5 inch springs front, m.o.r.e shackle reversal, m.o.r.e shock hoops, 3 inch springs in rear, bilstein 5150's, shock bar, m.o.r.e traction bar, lockers, m.o.r.e high steer, SYE, old school bronco cv shaft, tube fenders, 36 inch tsl's
91yjwrangler6 is offline
post #3 of 5 Old 10-19-2007, 12:00 PM
bamato
bamato's Avatar
There is a chemical out there that will actually fuse the two pieces together. I'd go for that, most big auto stores carry some kind of it, or even ace hardware.
/l , [____],
l---L--?lllllll?-
()_) ()_)----)_)
Mud is your Friend :)
Tread Lightly
Please help keep our trails clean for future generations to enjoy outdoor recreation as well!
bamato is offline
post #4 of 5 Old 10-19-2007, 12:04 PM
Wiretech
Look into Plastex.net I have used it to repair many plastic parts on my old motorcycle. And many other plastic items. Never had any issues with any of the repaired items
Wiretech is offline
post #5 of 5 Old 10-19-2007, 04:19 PM
GrimJeeper91
GrimJeeper91's Avatar
I picked up a plastic gas tank repair kit at the local auto parts store. Easy to use and no problems so far (6 months)...
'91 YJ 4.O, Auto, Rr. D60 w/ 35 Spline Alloy USA Axles & Detriot Locker, Fr. D30 True-Trac, 4.56's, 4.5" Deaver Springs, Bilstein 5100's, 1" BL, Rubi Flares, 35x12.50 MT/R's on MT classic II's, Detroit Locker, Vanco Big Brakes, Booster & Master, Warn 9000XDI, York OBA, AA SYE & TW's DS's, Teraflex Belly Up, Rocker Guards...
GrimJeeper91 is offline
To weld or not to weld (Dana 30) Polo YJ Wrangler Technical Forum 60 03-22-2012 09:50 PM
WAS...Going to Weld my 35 giggityjeeper YJ Wrangler Technical Forum 2 09-22-2008 12:17 PM
Jb Weld HAMM YJ Wrangler Technical Forum 9 03-28-2008 08:03 PM
Weld the 8.8 or not to weld the 8.8? kkiel02 TJ Wrangler Technical Forum 5 05-10-2006 07:18 AM
is it ok to tack weld the muffler with J&B weld? losfreddy TJ Wrangler Technical Forum 9 04-02-2006 10:22 PM
