plastic droped in transfer case - JeepForum.com
post #1 of 15 Old 09-17-2011, 02:33 PM Thread Starter
greenjeep94yj
I was changing fluid in my transfer case today (np231), all was going way too easy! As I was pushing the last few pumps of fluid in through a hand pump, the small plastic fill nosel shot off and into the case (note to self... never use that thing again!!!) . I have tried to finger sweep for it and can not find it. Is it ok if i leave it in there for a short time? Im thinking that the gears will chew it up within a few miles. Then I could just drain fluid and replace. Or do I need to split the case and pull it out?
Thanks for any help
greenjeep94yj is offline
post #2 of 15 Old 09-17-2011, 02:46 PM
moonshinefuel
You may be able to reach it by pulling the shaft housing off, "the cone", instead of having to split the entire case.
AX5/NV3550 Conversion Thread.
Bow Hunting
moonshinefuel is offline
post #3 of 15 Old 09-17-2011, 02:49 PM
MGDWJ
If you let the gears chew it up then more than likely it will plug the filter for the oil pump and could trash your t case.
MGDWJ is offline
post #4 of 15 Old 09-17-2011, 02:53 PM
nembudonna
What do you call small?
nembudonna is offline
post #5 of 15 Old 09-17-2011, 03:16 PM
sbsg2005
Need to get it out. If it gets chewed up and clogs the pump pick up that little piece of plastic can cost you some big bucks to replace or rebuild the case.
sbsg2005 is offline
post #6 of 15 Old 09-17-2011, 03:32 PM
nsahan
there's no pump in the transfer case only the engine the gears lay in fluid run it for a week and change the fluid but i don't think the pieceof plastic will hurt anything
nsahan is offline
post #7 of 15 Old 09-17-2011, 03:42 PM
nembudonna
I never heard of a pump or filter in the transfer case.
post #8 of 15 Old 09-17-2011, 03:59 PM
dancytron
Sadly, I did the exact same thing about a year ago.
I changed the fluid again in about a month.
Other than that, I try not to think about it and have been very successful until you reminded me.
dancytron is offline
post #9 of 15 Old 09-17-2011, 04:02 PM
hatfield44
They are both in there
hatfield44 is offline
post #10 of 15 Old 09-17-2011, 04:07 PM
4.7stroker
Yup there is a pump and pick up in the xfer case. I would not risk it but hey it is not my rig.
Dwayne
[url]
Prevent Flat Tappet Cam Failure.
[url]
4.7stroker is offline
post #11 of 15 Old 09-17-2011, 04:11 PM
nembudonna
I didn't know that. Thanks
post #12 of 15 Old 09-17-2011, 04:14 PM
nembudonna
Ididn't know that. Thanks. What is the pump doing. I mean why does it need a pump?
post #13 of 15 Old 09-17-2011, 05:01 PM
nsahan
yeh i didn't know that either.i just checked the manual its there
nsahan is offline
post #14 of 15 Old 09-17-2011, 07:01 PM
Alabamaranger
Maybe pull the drain plug and it will float out with the fluid. Fill and drain until it comes out.
90 YJ, 4.2 with 2150 carb 4.0 Head and headers, Nutter with TFI and MSD. 1" BL, 2.5" spring lift, 33", Goodrich KM Mud Tires. Dana 30 w Aussie, Ford 8.8 w LS. 9000lb HF Winch.
Alabamaranger is offline
post #15 of 15 Old 09-17-2011, 07:57 PM
leftlanetruckin
XJ on 37's
leftlanetruckin's Avatar
There has to be a pump in there to circulate the fluid.......
OP, try draining it and see if you can feel it as the fluid (hopefully) pushes it towards the drain plug. If not, I wouldn't run it like that myself.
Sounds like a good time to install a SYE if it doesnt come out!
Martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.
2003 Range Rover HSE, 4.4 Quad Cam.
1998 Range Rover with a 6.0 LSx
1994 YJ, 4.3/700R4/OME SOA, etc
Western Star 4900EX 4 axle.
4.3/700r4/new frame buildup (YJ)....
leftlanetruckin is offline
LOUD violent POP from transfer case on occasion from my lifted Rubicon transfer case anymanusa TJ Wrangler Technical Forum 14 07-23-2010 04:54 PM
Transfer case boot for 231c transfer case in jeep wrangler kniteman YJ Wrangler Technical Forum 2 03-16-2009 01:28 PM
Bent rear diff and cracked transfer case, what diffs and case will bolt into my 87 YJ hillside250 YJ Wrangler Technical Forum 9 01-08-2009 12:45 AM
Diff and transfer case fluid transfer hint BillArf TJ Wrangler Technical Forum 11 06-26-2005 07:42 AM
Newbie question..found plastic pop bottle in between transfer case and skid plate? tbu72 TJ Wrangler Technical Forum 13 10-26-2004 07:54 PM
