Planning out my stretch/soa - JeepForum.com
post #1 of 12 Old 01-16-2012, 12:15 AM Thread Starter
Unii
This past week I've been doing a lot of dreaming and I've decided once my job situation gets better I'm going to tear into the jeep again. I have settled on staying with leaf springs and going SOA. With that I'm thinking of stretching it while I'm doing it.
Been doing a lot of searching on here and PBB and I'm thinking of wagoneer springs in the rear or stock yj's due to my 8.8 almost hitting my tank as it is now. The front I'm thinking XJ springs with high steer and an astro van steering box, maybe even offset perches also to get me at that 100"+ WB I'd like to have.
I'll be sticking with my 35's for the time being maybe going back to 37 if I found a good deal. But in the long run I will eventually have one tons and 40s or so, so I don't want to regret something of have to change anything.
Also I plan on a undercoverfab high clearance skid and SYE with a traction bar in the rear. Just wondering if my plans had any major issues or if I would benefit from a different route.
Unii is offline
post #2 of 12 Old 01-16-2012, 06:06 PM Thread Starter
Unii
Nobody?
well I'm ordering metalcloak front fenders tomorrow.
Unii is offline
post #3 of 12 Old 01-16-2012, 06:39 PM
cherokee106
if you wanta stretch the front use xj springs i used them they work great, got about 6" stretch had to get a short pitman arm but it worked better with a heim joint steering system.
1972 bullnose commando 304 amc soa with 4" cj lift springs, 35s and rancho shocks. nothing special. YET
cherokee106 is offline
post #4 of 12 Old 02-21-2012, 10:41 AM
94YJCRAIG
would you happen to have a part number or a select years that the astro van box's come out of?
94YJCRAIG is offline
post #5 of 12 Old 02-21-2012, 10:47 AM
scubamc
http://www.pirate4x4.com/forum/showt...+front+stretch
google is your friend.
scubamc is offline
post #6 of 12 Old 02-21-2012, 11:17 AM
fratis
fratis's Avatar
if you get a ucf get the flattest one possible and modify the tunnel. with that much stretch and 35s you are going to need some belly clearance.
id like to see someone simply move the frame hard mounts.
be careful when using short pitman arms you can loose potential steering radius that way.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #7 of 12 Old 02-21-2012, 11:17 AM
dillonjm
2013 WK
I forsee one issue. That being with your proposed Belly up and not really stretching the rear any, specifically driveline angle and bind @ the double cardan joint. In fact, I added a MML to help combat this and am happy with where it sits now.
With my 4" suspension setup (3.5" springs, .5" shackles) and I am what I'd consider close to the limit for angle on that double joint @ droop. You're going to have significantly more suspension than I do SOA.
You could maybe solve that with a higher angle setup than what the normal Tom Woods shaft has, I think they offer higher angle offset joints, but don't quote me.
13 GC Overland - (Wife's DD) 5.7, stock
Past Jeeps: 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #8 of 12 Old 02-21-2012, 02:25 PM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
don't let the gas tank and its location limit your plans. I would honestly rather have a fuel cell and the stock skid than the extra inch below. then you can stretch to any distance in the rear.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #9 of 12 Old 02-21-2012, 04:29 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Having a stretched rear axle does start to invade the gastank's space a little bit. I'm rubbing on mine when I go over speed bumps and am considering just putting the axle where it would go stock. The only problem I forsee on mine is the driveshaft has already served me so well already.
Luck Favours The Prepared
Anticanman is offline
post #10 of 12 Old 02-21-2012, 04:48 PM
E_ROCK
I am at 103" wheel base. Front 6" stretch with 4" stretch in the rear.
Front stretch starts at post #25
Rear stretch starts at post #30
http://www.jeepforum.com/forum/f12/e...build-1151311/
Garage Monkey, Wheeling Junkie
E_ROCK is offline
post #11 of 12 Old 02-21-2012, 07:02 PM
ssyj94
I agree with fratis
I'd just move the hangers back with a set of say 1.5" re soa springs. A friend did it to his yj and it works.
Also if your moving the rear axle 2" you'll have to deal with the tank being right where you want your axle. Either the mold a bump routine, genright or cell deal. I'm about 4" back from stock and just found a comp tank on PBB for cheap. So far I like the tank but despite what genright claims it hangs down 6" from the frame a hair more than stock. I've been hacking up the rear crossmember and managed to cram it up about 3" with a 1" body lift.
My build:
ssyj94 is offline
post #12 of 12 Old 02-21-2012, 10:40 PM
fratis
fratis's Avatar
Bfh...
fratis is offline
Planning a lift & stretch on a '90 YJ shadowulf YJ Wrangler Technical Forum 1 02-15-2010 08:50 PM
Clayton's long arm and 5" stretch or the double triangulated with the stretch? Haz-Mat TJ Wrangler Technical Forum 14 08-14-2009 07:44 PM
Planning to get a TJ. How much should I pay. JMC-14 Wrangler General Discussion 9 02-15-2009 08:51 PM
More planning schizm99 YJ Wrangler Technical Forum 0 02-07-2009 02:13 PM
anyone tried the clayton stretch kit or a custom stretch setup bluejeep2088 TJ Wrangler Technical Forum 5 02-01-2007 08:04 PM
