Plan on getting 33's in the future...question - JeepForum.com
post #1 of 4 Old 07-20-2004, 06:22 PM Thread Starter
Rynxprs
I have 31's right now and I could use a 1" or 2" of clearence.
I've been told that I need atleast a 3.5"- 4" lift to fit 33's.
So...should I just save and get a 3.5" - 4" lift or would it be a problem if I were to get a 1" body lift and a 1" Shackle lift (.5" total shackle lift) now for a 1.5" lift...and get a 2.5" lift later when I buy the 33's.
Getting the 33's wont be for awhile...maybe not even till after the upcoming winter.
1993 XJ - 4.0, Auto, 3" RE Lift, AR 15x8 Diamond Back Rims, 32" Kuhmo MTs, CRB Front Bumper, CRB Rear bumper w/Tire Carrier, Surco Roof Rack, New Floor Boards :)
Rynxprs is offline
post #2 of 4 Old 07-20-2004, 07:37 PM
Devious
Hobo Shanker
Devious's Avatar
2014 JK Wrangler
From the FAQ's,
What size of tires fit without rubbing?
Older YJ (sagged springs on stock rims with lots of miles) - 235/75r15
Newer YJ (non-sagged springs on stock rims with few miles) - 30x9.5r15
Newer YJ (non-sagged springs on non-stock rims with few miles) - 31x10.5r15
2.5" lift on stock rims - 32x10.5r15
4" lift on stock rims - 33x12.5r15
Go for the 4" kit.
Life is tough enough already, but it's even tougher when you're stupid
Devious is offline
post #3 of 4 Old 07-20-2004, 08:24 PM
hmk_21
they bolt on with 3.5" but id most def want more clearance..
so i went with a 2" BL fixed that issue.
see sig
89 Yellow YJ Islander 4.2L *decal free*
hmk_21 is offline
post #4 of 4 Old 07-20-2004, 09:29 PM Thread Starter
Rynxprs
So you think if I go ahead and get a 1" Body Lift plus the 1" Shackles (which would be 1/2" lift) that later on when I get the 33's I'd be fine with getting a 3.5" lift then correct?
What about the ride....would that set up be good or would just a 4" lift and nothing else be better?
thanks.
Rynxprs is offline
winch sag plan of attack...3" BDS and 33's..yes/np/ msumike1 TJ Wrangler Technical Forum 13 09-15-2009 08:29 PM
Plan to buy, have question about top. FlashDawg JK Wrangler Technical Forum 10 01-28-2008 11:08 PM
Opinions on future Plan Wynne TJ Wrangler Technical Forum 8 02-20-2007 03:45 PM
Lift Plan and BL Kit Question robert92679 TJ Wrangler Technical Forum 6 11-08-2006 12:16 PM
question for my lift plan wrnglrguy TJ Wrangler Technical Forum 2 08-06-2006 07:36 PM
