Pitman arm removal trouble. - Page 2 - JeepForum.com
post #16 of 36 Old 04-22-2013, 09:04 AM
Que89YJ
1 5/16" or a 34mm.
Que89YJ is online now
post #17 of 36 Old 04-22-2013, 09:38 AM
crackedcornish
Originally Posted by Que89YJ View Post
1 5/16" or a 34mm.
thank you
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #18 of 36 Old 04-22-2013, 09:58 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
If the reason to get the 15+ yr old pitman off is to put on a new one, I wouldn't hesitate to take an angle grinder w/cutoff to the pitman and put a slit in it to pop it open.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #19 of 36 Old 04-22-2013, 10:09 AM
CrawlingForward
This.
If you're replacing it anyway, it's not worth the aggravation fighting with it.
Notch it 90% of the way on one side, and if it doesn't go, notch it on another side. Give it a few taps and it should just pop apart on you.
Way quicker, way easier.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #20 of 36 Old 04-22-2013, 11:36 AM Thread Starter
randall979
Originally Posted by crackedcornish
not to hi-jack but, my pitman arm needs to be removed so I can install the dropped arm that came with my lift...I don't have the correct size socket, anybody know what size the nut is?
I don't really want to use my big pipe wrench on it
33mm
randall979 is offline
post #21 of 36 Old 04-22-2013, 04:59 PM
jokerchief462
Stop screwing around and cut it off with a 4" angle grinder. You cut almost all the way through what is called a relief cut and then put the puller back on. It is difficult at best to cut all the way through without cutting into the steering box output shaft So you stop short the puller will exert enough pressure to use the cut for relief and then it comes off.
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #22 of 36 Old 04-22-2013, 05:22 PM
bill8bud
Originally Posted by CrawlingForward View Post
This.
I had to do this to mine to get it off.
I feel your pain.
bill8bud is offline
post #23 of 36 Old 04-22-2013, 05:38 PM
Steve707
I broke a puller from harbor freight when i did mine, rented the 4wd one from autozone and that did the trick.
Steve707 is offline
post #24 of 36 Old 04-22-2013, 05:40 PM
UZI4U
I soaked mine with Kroil every day for a few weeks and put on the puller. A sharp rap with the hammer and it popped.
MCLMM
UZI4U is offline
post #25 of 36 Old 04-22-2013, 06:35 PM
Rproject
1987 YJ Wrangler
When I had to replace my gear box, I couldn't get mine off either. I swear I beat on it for over an hour and PBed it to hell and back again. Finally gave in and called my mechanic buddy. He came by with a 3lb and 5lb mini sledge. Literally three big whacks later he had it off. I told him I loosed it for him. LOL
1996 White ZJ
1987 Maroon YJ (sideways build)
1996 Forest Green XJ
The "sideways" build thread:
Rproject is offline
post #26 of 36 Old 04-22-2013, 06:53 PM
USMCBuckWild
This. I would STRONGLY advise this.
Don't be afraid to apply heat and cold. I'm not saying a fire extinguisher gets REALLY cold when applied properly to parts, but my pitman arm literally popped right off when covered in a little white powder.
Hot and cold do different things to steel. Just saying.
91 YJ, 350/700R4/231, 8.8/HPD30 with 3.73s, 6" SOA with 38" TSLs. If I ever see the previous owner again, I am going to curb stomp that meth-head brain dead crackpot.
USMCBuckWild is offline
post #27 of 36 Old 04-22-2013, 09:36 PM
rinking
I like to put a puller on it and put some good pressure on it, I've got a nice 5 foot spud bar/ straight crowbar, that I thread down between the radiator and grill, from the top (under the hood) and rap on the pitmen arm as close to the splines as space allows. I live in the salt belt and this method has worked great.
rinking is offline
post #28 of 36 Old 04-23-2013, 03:39 AM Thread Starter
randall979
Originally Posted by Louie4
You must have gotten the cheaper pitman arm puller. I rented the heavy duty from Autozone and I would be very surprised if you broke it. It was around $90 for renting but well worth it. See pic.
Of course I've used the other one like fratis said with good results.
This worked. It was 90$ to rent but well worth it. I did cut into it with the sawsall I think that helped too. And the drifting problem is a lot better too. Now to get the drag link adjusted......
post #29 of 36 Old 04-23-2013, 04:46 AM
insaneinline
I cut slit in mine to actually like a v notch out of it came of easy after that
insaneinline is offline
post #30 of 36 Old 04-23-2013, 07:28 AM
JeeperDon
JeeperDon's Avatar
What? A $90 rent is 'well worth it'? If all you had was a sawsall you could have bought an angle grinder and a dozen cutoff wheels for that and had change left over, and a great tool for the future when done.
Can I have a grant?
Web Admin for
