piss poor power - JeepForum.com
post #1 of 4 Old 05-29-2001, 09:59 PM Thread Starter
mike byrd
piss poor power
I have a '90 YJ with the 999 automatic in it. Because of the crummy gear ratio I don't have power worth a crap (motor is fine....) any CHEAP ideas to get the ratio down to something I can live with?
'90 YJ, 4.2 liter, 4"Pro Comp Lift, lookin for other goodies.
mike byrd is offline
post #2 of 4 Old 05-30-2001, 12:47 AM
osburn
osburn's Avatar
There's only one way to change the ratio in 2 high, which is what I assume you're talking about. If not, then a 4:1 kit for your tcase will do the trick for around $1000. If the problem is on the road, then the only thing you can do, aside from a different tranny, is re-gear the axles. That'll run ya about $250 an axle in parts. I think labor will run about the same.
I almost forgot. You could run smaller tires!
Matt Osburn
Score 1032
osburn is offline
post #3 of 4 Old 05-30-2001, 12:54 AM
FLHT_FXRS_YJ
FLHT_FXRS_YJ's Avatar
Has it always had lack of power? My 4.2 yj had a plugged converter and it just kept losing power over time. I had no idea that the converter was the problem until I had to get out the tow strap to get home one day.
89' YJ - 4.2 - NV4500 - NP231w/sye - 1" Body Lift - 2 1/2" Rancho Suspension Lift - 31" Firestone MTR - AR Outlaw II - Tomken Bumpers F & R - Warn 8000 front - Warn 6000 rec. mount rear - FlowFit Seats - Tom Woods Rear & Custom 2" front driveshafts
FLHT_FXRS_YJ is offline
post #4 of 4 Old 05-30-2001, 05:36 AM
Hara
I'm running 35"s with a 4.56 gear ratio, and the engine runs slightly higher than stock
Hara is offline
no power, poor performance ronfezz YJ Wrangler Technical Forum 14 02-23-2010 09:56 PM
Little things that piss me off! gregpalin YJ Wrangler Technical Forum 4 09-21-2009 12:50 AM
No Power, Poor MPG, Overheating...WTF? JeepRat TJ Wrangler Technical Forum 4 07-20-2008 01:50 PM
Sad day, what to do with my poor YJ? hokiehoo YJ Wrangler Technical Forum 18 05-17-2007 09:50 AM
I want to piss and moan about my Dodge Truck.... danheit YJ Wrangler Technical Forum 27 02-05-2007 03:34 PM
