Quantcast Pipe Burst, Know the Name? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Pipe Burst, Know the Name?
Old 03-23-2008, 10:06 PM   #1
Delta347
Ask the guy above me
Delta347's Avatar
The Pipe Leading from my CC along the passenger side up into the Carb. burst recently resulting in an obvious reduction in power.
Does anyone know this pipes name and/or part number by chance?
1990 I-6 Auto 4.2L
In the mean time a layer of aluminum held on by a "Tiger" Self-bonding patch is keeping the part in check.
Originally Posted by Leans93 View Post
So ghost has a plug in his hole and opihi has a gaping hole, Do I need to worry about this hole at all? I just don't want to start her up and have something spewing out of it.
Side Effects may include dry mouth, nausea, vomitting, water retention, painful recolage, hallucination, dementia, psycosis, coma, death, and halitosus. YJs are not for everyone please consult your physician before use.
Delta347 is offline   Reply With Quote
Old 03-23-2008, 10:22 PM   #2
jbolty
ISO 9001 Compliant
jbolty's Avatar
part of the pulse air emissions system. nothing special about the pipe itself, just pipe. But all that stuff has to be working for the smog system. patch it if you can or splice in a piece of pipe. I doubt if you will find a replacement easily.
PS
If you are in San Diego, are you checking in here?
http://www.jeepforum.com/forum/f262/san-diego-area-214660-post4989778/#post4989778
Originally Posted by Stimpdezracer View Post
Cross threading is as good as lock-tite
If you live within wheeling distance of San Diego county, click here
jbolty is offline   Reply With Quote
Old 03-24-2008, 01:06 AM   #3
Delta347
Delta347's Avatar
Yeah kinda figured it would be just pipe, ill find a interior diameter matching the outside of the broken pipe eventually I suppose.
As for the thread thanks for linking it! Me and my YJ buddy are always looking for new adventures and people to meet.
I think I have seen your Jeep around (if you drive up/down the I-5 between Point Loma/Del Mar sometimes.) that or there are other white jeeps with red doors out there.
Old 03-24-2008, 07:41 AM   #4
jbolty
ISO 9001 Compliant
jbolty's Avatar
That tube system is crazy complicated with about a million parts. I ripped all mine out last year and put in a howell tbi. unfortunately I sold most the parts to someone already. I have lots of notes though on what goes where and what ir does so I may be able to help you with it.
meantime here is a source of a lot off good information.
http://jeep.off-road.com/jeep/tech.258bbd/A-Primer-on-the-Jeep-258-with-Carter-BBD--Pulse-Ai/ArticleStandard/Article/detail/261400
http://jeep.off-road.com/jeep/article/articleDetail.jsp?id=261381
Probably me. I live in clairemont and work in downtown, pt loma or mission valley and I do go up to carlsbad sometimes.
We have a good local group here in san diego and just had a great run thru corral canyon yesterday and planning to get in some overnight trips before it gets too hot.
Old 03-24-2008, 06:45 PM   #5
laybackman
laybackman's Avatar
TUBE-pulse air downstream #5200 2519 from a jeep parts manual BUT I would just substitute it with a piece of metallic tubing of some kind.
laybackman is offline   Reply With Quote
Old 03-24-2008, 06:48 PM   #6
vtjeepthing
Copper tube with compression fittings should work
A big Jeep requires a bigger wallet!
vtjeepthing is offline   Reply With Quote
Old 03-24-2008, 07:03 PM   #7
Burnerman
That pipe is about $40 new from the dealer. Check NAPA, they may also have a replacement available. Where did it split? You may find tubing one size bigger and clamp or weld it in place of the bad spot.
89' YJ Larado 4.0L,AX15
01' Grand Cherokee 4.0L
Check my Gallery for pics.
My Rebuild Thread
Take a minute and fill out your profile, Please
Burnerman is offline   Reply With Quote
Old 03-28-2008, 02:41 AM   #8
Delta347
Delta347's Avatar
In response to Burnerman,
the pipe burst on the end closer to the CC itself, there is an L-joint like pipe coming out, and then a tiny U bolt, the burst is about 2-3inches forward from the U bolt holding the L pipe and the rest of the pipe that leads to the carb together.
So If i can't find anything at Napa, I think I will go with welding a piece of sheet metal over it if I don't just buy a similar sized one. Haven't had the time to go check out prices near home or even get to it since I started restoring a 1951 Studebaker Champion >.> (Project from a fine female friend).
Old 03-28-2008, 03:11 AM   #9
kharmajavah
If you don't want to fab, check here: http://www.teamwrangler.com/Emissions/index.html
...and, check the CJ forum. Many masters of the 258 reside there.
kharmajavah is offline   Reply With Quote
Glock Forum
