Which pins going to the ECU should be hot with the key on? - JeepForum.com
post #1 of 4 Old 09-01-2011, 05:37 PM Thread Starter
AnonymousD
Im trying to track down the problem in my '92 4.0L. I tested all the pins and I get 12V on only the #3 pin. All the other pins are dead with the key on.
This is of course, with the computer out of the vehicle.
AnonymousD is offline
post #2 of 4 Old 09-01-2011, 06:01 PM
kloppk
Pin 9 should get 12 v from the ignition switch with the key in the Run position.
Pin 3 should have 12 v on it all the time regardless of the key position.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 4 Old 09-01-2011, 06:07 PM Thread Starter
AnonymousD
Ok. So looks like it is probably my ignition switch then. Im getting 12V to pin 3 at all times, but nothing to pin 9 with the key on or off.
Sound about right?
post #4 of 4 Old 09-01-2011, 06:12 PM
oldtime_ironman
I think this link probably explains all of it. He has all that info in his write-up.
http://www.jeepforum.com/forum/f12/9...plained-490788
But yeah that would explain a lot about your ECU if only pin 3 is getting it.
oldtime_ironman is offline
AW4 Swap into YJ, TCU 26 pins vs 32 pins? thuggles YJ Wrangler Technical Forum 0 09-14-2009 10:58 AM
need help with centering pins (again) drew2000 YJ Wrangler Technical Forum 22 07-05-2006 08:47 PM
which center pins? Johnny World YJ Wrangler Technical Forum 2 06-14-2006 04:14 PM
hinge pins tiny terror TJ Wrangler Technical Forum 6 06-07-2006 05:58 PM
gas gauge pins oil pressure gauge pins rsgweld YJ Wrangler Technical Forum 1 09-11-2005 06:44 PM
