Pinion angle - Page 2 - JeepForum.com
post #16 of 22 Old 04-21-2013, 11:44 AM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Originally Posted by phil1330
Then you should not have a problem getting a good pinion angle
Yes i know but what angle should it be
jakesjeepmj1988 is offline
post #17 of 22 Old 04-21-2013, 12:28 PM
phil1330
1964 CJ5
im at 26 degrees with soa and 4'' springs plus shackle lift. That is close to the max angle it can be. with just soa you should be around 22ish. probably need to drop the tc case down 1/5 inch or may be even 3/4 of inch. you can also move your rear end back 1 inch with the 3 hole spring perches to help achieve an even better angle. I have my rear end set 1 degree less than the driveshaft angle. you can go up to 2 or even 3 degrees less than but that is tops. This is for axle wrap.if you have a torque arm or traction bar i would leave it a 1 degree less than drive shaft angle.
Also there are tons and tons of these threads on here on this topic you can read up on.
hopes this helps
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #18 of 22 Old 04-21-2013, 12:35 PM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
hopes this helps
Thank you sorry im not really a yj person im helping my uncle and cousint build it
post #19 of 22 Old 04-21-2013, 01:59 PM
fratis
fratis's Avatar
your angle will be determined by our setup not what others have done.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #20 of 22 Old 04-21-2013, 03:58 PM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Ok thanks
post #21 of 22 Old 04-21-2013, 06:57 PM
jbolty
jbolty's Avatar
You should be at ride height when you set the angles so with a stripped tub you might need to add some weight or set the height without springs using a bunch of jackstands.
jbolty is offline
post #22 of 22 Old 04-21-2013, 07:35 PM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Ok thank you
