Pinion angle - JeepForum.com
post #1 of 22 Old 04-20-2013, 10:49 AM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Pinion angle
Im putting a 8.8 soa on my 95 what angle should it be?
jakesjeepmj1988 is offline
post #2 of 22 Old 04-20-2013, 11:06 AM
booboowv77
There is no set angle, and alot of different things affect the pinion angle. If I was you I would do a quick search. I just did mine and it is set at 22 Degrees but I went with SOA, SYE and a CV Shaft.
GOOGLE IS YOUR FRIEND!!!
Just my toy!
89 YJ, Fresh 4.0, ax15, SOA w/410's, and about a million other things! :)
Built not Bought #759
booboowv77 is offline
post #3 of 22 Old 04-20-2013, 01:27 PM
fratis
fratis's Avatar
if you are doing a SOA you should already have a good understanding of how it should be setup and why.
-insert meaningless out-of-place political diatribe-
fratis is offline
post #4 of 22 Old 04-20-2013, 01:34 PM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Im doing it with a 8.8 its my first time doing it with this axle
post #5 of 22 Old 04-20-2013, 02:06 PM
TrentYJ
A lot of people seem to like to measure it in line with the transfer case yoke then set it 2 degrees off of that to take into account the twist from the torque on the wheel when u apply power to the drive train. I've just seen that setup to be pretty common. I don't know if its preferred for your setup but it will only work well with an sye installed. Do a little more digging around before you tack anything up but nothing should be different with an 8.8 compared to a different rear end.
"Arguing over the internet is like running in the Special Olympics...Even if you win, you're still retarded."
-François-Marie Arouet
TrentYJ is offline
post #6 of 22 Old 04-20-2013, 04:21 PM
jbolty
jbolty's Avatar
This.
There is a lot more to this project than just re-welding the spring perch.
None of us know your plans or skill level but we have seen countless SOA project go horribly wrong for lack of planning.
Where's the whole project at?
jbolty is offline
post #7 of 22 Old 04-20-2013, 04:39 PM
skyj
Here is his thread about the front. lol
http://www.jeepforum.com/forum/f12/p...angle-1511979/
build thread:
skyj is offline
post #8 of 22 Old 04-20-2013, 08:42 PM
TSEJEEPERS
nevermind
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #9 of 22 Old 04-20-2013, 08:44 PM
TSEJEEPERS
SYE or not?
post #10 of 22 Old 04-20-2013, 09:35 PM
phil1330
1964 CJ5
Get a torque arm. Your gonna have axle wrap.
"Life is hard, it's harder if your're stupid"...The Duke
phil1330 is offline
post #11 of 22 Old 04-20-2013, 09:42 PM
TSEJEEPERS
What is a torque arm?
post #12 of 22 Old 04-20-2013, 09:56 PM
phil1330
1964 CJ5
Same as your homemade traction bar.
phil1330 is offline
post #13 of 22 Old 04-21-2013, 08:55 AM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Yes sye
post #14 of 22 Old 04-21-2013, 08:57 AM Thread Starter
jakesjeepmj1988
1988 MJ Comanche
Originally Posted by jbolty
This.
Heres were its at
post #15 of 22 Old 04-21-2013, 11:40 AM
phil1330
1964 CJ5
Yes sye
Then you should not have a problem getting a good pinion angle
phil1330 is offline
