Which pilot bushing? - JeepForum.com
post #1 of 8 Old 03-03-2013, 10:19 AM Thread Starter
95yj0645
I have a 93 4.0 with an 88 258 crankshaft. Which pilot bushing do I need to get to bolt my ax15 up to it?
95yj0645 is offline
post #2 of 8 Old 03-03-2013, 12:11 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
I'd say for an 88. Ask Rock Auto.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #3 of 8 Old 03-03-2013, 12:15 PM
BIGHEEP
Advanced adapters. The 88 bushing will not fit the input of your ax-15. When I put my 4.0L HO infront of my early style AX-15 I used a 258 bushing and tunred the OD down in a lathe so it would fit the 4.0L crank.
1981 Scrambler, Vortec 350,4L60e,D300, Currie 9" F&R
19xx YJ/CJ/TJ/XJ/Waggy thing 4.0L H.O., AW4,
NP231 w/HD SYE,D44 locked/D44 w/LSD,4.09 gears
Build thread
North East Willy Jeep Organization
BIGHEEP is offline
post #4 of 8 Old 03-03-2013, 12:17 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
It's also a function of what you are plugging into it. Different transmissions over the years have different pilot bushing ID needs.
Web Admin for
post #5 of 8 Old 03-03-2013, 12:33 PM
BIGHEEP
That is what I was getting at. Mine was a 1990 ax-15 which had the small input they used behind the 258. If your ax-15 is the stock 1994 that came with it the input will be larger. Now if you did have the early style ax-15 you would just use 80-91 6 cyl. CJ/YJ bearing. Your best bet would be call Advanced Adapters and tell them what you are trying to do and they will hook you up with the right bushing.
Build thread
BIGHEEP is offline
post #6 of 8 Old 03-03-2013, 05:07 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I don't remember which year the pilot snout increased from 0.590" to 0.750", but if you have the smaller one, a stock pilot bushing will work from an '88. If you have the larger one you'll likely need to get a custom one that fits the ID of the crank shaft and the OD of the transmission.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #7 of 8 Old 03-03-2013, 05:56 PM Thread Starter
95yj0645
Sounds like I just need to mic the crank and the input shaft and go from there. I believe it is the newer style ax15.
95yj0645 is offline
post #8 of 8 Old 03-03-2013, 06:54 PM
JeeperDon
Join a 4x4 Club
JeeperDon's Avatar
It's a cheap part. Buy both, then tear into it knowing you're covered.
Web Admin for
