Pilot Bearings 101 - Page 2 - JeepForum.com
post #16 of 24 Old 01-29-2008, 08:58 AM Thread Starter
Opihi59
from here it gets rough
Opihi59's Avatar
SwedishD, now that is an impressive little tool there. I suppose it works better for the solid bushing type pilot rather than the needle bearing type as the threads may not engage in the needle bearing type pilot. Very interesting little tool........grease hydraulics without the dowel and hammer.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #17 of 24 Old 01-29-2008, 09:26 AM
426Savoy
I just got through trying the Lisle grease pressure tool. It won't work for the steel roller pilot bearing on the Jeep which I suspected. It does state on the package, not to use on steel. I'll keep it back for brass or bronze bushings. I did use the above method using a bolt behind the pilot bearing and it worked great.
Hopefully this afternoon, I'll have the engine back in the Jeep. It's
suppose to snow on Thursday. Too bad it won't be ready by then.
426Savoy is offline
post #18 of 24 Old 10-12-2008, 08:57 PM
jpfix
that grease method is a whole lot of grease. I tried that today, and there is a big void behind the flywheel and the crank.
I cheated...i pulled the flywheel & drove the old sucker out
91 YJ Runs 79 CJ5 waiting for winter
YJ - one step away from a CJ = lots of interchangeable parts.
TJ - one step away from a JK = sudden urge to go to the mall
jpfix is offline
post #19 of 24 Old 10-12-2008, 09:04 PM Thread Starter
Opihi59
Opihi59's Avatar
jpfix...I'm confused. The pilot bearing is inside the end of the crank, not inside the flywheel proper. Tell me more. Glad whatever you did worked for you though.
Edit--on the 4 cyl, the pilot bearing/bushing is installed in the flywheel, whereas in the 6 cyl, it is installed into the back end of the crank
Opihi59 is offline
post #20 of 24 Old 10-12-2008, 09:17 PM
jpfix
I always thought that too...but this crank on the 2.5L is smmoooooth on the inside, about the size of half a golfball. there is a rollerbearing in the flywheel, carries the shaft going into the transmission. maybe it is a thing with the early 90s 4cyl. the pilot bearing that comes in the clutch kit fits nicely in the center of the flywheel...three easy raps drive it into place.
jpfix is offline
post #21 of 24 Old 10-12-2008, 09:39 PM Thread Starter
Opihi59
Opihi59's Avatar
Interesting. I haven't seen this before. Of course that doesn't mean it isn't normal for many different vehicles, and certainly I am not universally experienced in pilot bearings in all vehicles. Interesting nonetheless.
Opihi59 is offline
post #22 of 24 Old 02-15-2011, 03:30 AM
shinerm02
Tried this last night and it worked very easy. I just used a socket bigger than the pilot bushing though. No mess, no grease and out in very little time. Thanks for the idea.
That is why I like Jeep Forum...you can find little ideas to make the job easier. And I ended up with this.
There's life after death and taxes
shinerm02 is offline
post #23 of 24 Old 08-18-2011, 10:30 AM
rspoth
Thank you for posting that - you are a genius. I was really stuck and executed (roughly) on your idea and out it came. You saved my XXX.
rspoth is offline
post #24 of 24 Old 08-18-2011, 10:42 AM
yotefever
1987 YJ Wrangler
You guys brought this thread back a little late for me I ended up with a tool I rented from Advanced auto but like yours better.
The 'socket' method is just like a stuck case remover for reloading metal ammo, I made my own but didn't think to use it for my pilot bearing.
yotefever is offline
What's a pilot bushing Bigboyky YJ Wrangler Technical Forum 22 11-09-2009 08:19 PM
92 4.0 Pilot Bearing ???? Backpoints YJ Wrangler Technical Forum 1 11-08-2009 01:13 AM
Pilot bushing with no pilot bearing? Poppy360 TJ Wrangler Technical Forum 0 07-19-2009 06:27 PM
Pilot bearing too big? veritas4156 YJ Wrangler Technical Forum 4 08-23-2008 01:48 PM
Pilot Bearings rlk_99 TJ Wrangler Technical Forum 1 01-08-2008 09:46 AM
