Pilot bearing installation - JeepForum.com
post #1 of 9 Old 01-28-2008, 07:43 PM Thread Starter
Opihi59
from here it gets rough
Opihi59's Avatar
I suppose enough people have seen my homemade pilot bearing puller, submitted yesterday.
I ran into problems on the bearing install. While the FSM makes a point about installing the new pilot bearing "Bearing seal must face transmission" in ALLCAPS and bolt print, I could not discern any difference between either end of my new pilot bearing. This apparently was a practical demonstration of the 50-50-80 rule which reads if there is only 2 ways to do something, then 80 percent of the time you will chose the wrong solution. I put mine in backwards, it would no longer turn when I checked it so there was another last minute dash to the parts store but they had one for $8. Turns out the new new one was not as long as the first new one, but I had the chance to compare them critically and noted that one end of the bearing race is sturdier/thicker and more flat. This would be the side to tap against. The end which goes into the end of the crank is rounded slightly, and is comparatively much thinner. So of course, I had chosen the wrong end. 50-50-80..... Another tip would be the part number is engraved on the face of the thicker end. If logic applies to automotive mechanics, it would make sense to be able to read a part number when the part is still installed. Photographs here for your comparison, In this photo, the THICK ends are shown, the shorter bearing has a beefier appearing "hit here with bearing driver" end: In the next photograph, the more fragile ends are shown, they are installed facing the engine:
I have installed at least a dozen or more pilot bearings in the last few years alone, but have never encountered this problem. This may of course be intuitive to many of the forum's experts, but hopefully this will help someone at some point from destroying the last spare pilot bearing available within 3000 miles, or on a Saturday evening of a 3 day weekend after the stores are closed up.
....I'm not smart, but I can lift heavy things.......
Fill out your PROFILE, and don't forget to look in the FAQ for writeups
I'm stuck on da Rock
Originally Posted by Brian4.2 View Post
We will be going Metric every inch of the way.
Originally Posted by 40dog View Post
yes I'm a some guy and have always put gasket sealer on my surfaces before mating
Originally Posted by Virjeep View Post
You should go to Pirate. I hear they are real smart over there. You'd fit right in.
Opihi59 is offline
post #2 of 9 Old 01-28-2008, 07:53 PM
timatoe
timatoe's Avatar
I ran into problems on the bearing install. While the FSM makes a point about installing the new pilot bearing "Bearing seal must face transmission" in ALLCAPS and bolt print, I could not discern any difference between either end of my new pilot bearing. This apparently was a practical demonstration of the 50-50-80 rule which reads if there is only 2 ways to do something, then 80 percent of the time you will chose the wrong solution. I put mine in backwards, it would no longer turn when I checked it so there was another last minute dash to the parts store but they had one for $8. Turns out the new new one was not as long as the first new one, but I had the chance to compare them critically and noted that one end of the bearing race is sturdier/thicker and more flat. This would be the side to tap against. The end which goes into the end of the crank is rounded slightly, and is comparatively much thinner. So of course, I had chosen the wrong end. 50-50-80..... Another tip would be the part number is engraved on the face of the thicker end. If logic applies to automotive mechanics, it would make sense to be able to read a part number when the part is still installed. Photographs here for your comparison, In this photo, the THICK ends are shown, the shorter bearing has a beefier appearing "hit here with bearing driver" end: In the next photograph, the more fragile ends are shown, they are installed facing the engine: IMG]http://i30.photobucket.com/albums/c315/Opihi59/DSCN2943.jpg[/IMG]
No Clicky
timatoe is offline
post #3 of 9 Old 01-28-2008, 08:03 PM
Richmond88yj
Eat, Sleep, Jeep
Richmond88yj's Avatar
That';s great info.
On the last two I did they were solid-ish, made of some oil impregated allow with no moving parts. Seem to hold up well, and no "which side first" issue.
Wonder which one is superior in lasting longer... I've always been a fan of the style you posted.
- Ernie
Richmond88yj is offline
post #4 of 9 Old 01-28-2008, 08:23 PM Thread Starter
Opihi59
Opihi59's Avatar
Looks like second photo link didn't work, will send photo number 2 once more:
Opihi59 is offline
post #5 of 9 Old 01-28-2008, 08:25 PM
Burnerman
Burnerman's Avatar
Lets try....
96 ZJ.
05' Grand Cherokee Limited, 2"OME lift
Burnerman is offline
post #6 of 9 Old 01-28-2008, 09:08 PM
doug_1994
doug_1994's Avatar
Same here, but mine is a conversion unit.
I kinda like this better for the reason its simpler...well it sounds good in my head anyways.
Wise men speak because they have something to say;
Fools because they have to say something.
Plato
doug_1994 is offline
post #7 of 9 Old 01-28-2008, 09:28 PM
swedishdwarf
swedishdwarf's Avatar
The bronze bushings last longer. You're not supposed to put anything on them, but I find a little ATF makes it easier to get the trans back in.
You can't teach an old dogma new tricks.
swedishdwarf is offline
post #8 of 9 Old 01-29-2008, 12:58 AM
oldballz
oldballz's Avatar
2011 JK Wrangler
Im puttin' this one in the mental bank for later on down the road. Great stuff.
oldballz is offline
post #9 of 9 Old 01-29-2008, 04:08 AM
Alfons
I found that the pilot bearings bought from a dealership have the seal, whereas third-party ones don't.
Alfons is offline
Pilot bearing & Throw out bearing?? gregb TJ Wrangler Technical Forum 40 06-29-2016 09:46 AM
Pilot bearing/Throwout bearing? TJ4JT TJ Wrangler Technical Forum 9 11-03-2009 01:07 PM
Pilot bushing with no pilot bearing? Poppy360 TJ Wrangler Technical Forum 0 07-19-2009 06:27 PM
Pilot Bearing - 91 AX-15 to 97 4.0 kloppk TJ Wrangler Technical Forum 3 12-10-2007 08:51 PM
Pilot Bearing Installation mrbigglesworth YJ Wrangler Technical Forum 3 02-19-2007 11:04 AM
