Pigeon toed allignmnet help needed...look here
#1 | |
I installed a SOA kit and I noticed my front tires started to wear uneven. I tried adjusting the OTT steering but made it worse. Is there something else I can adjust to fix it. My local allignment shop was no help and failed to inform me of the problem when they 1st did the allignment after the lift.
93 renegade |
#2 | ||
Adjusting the drag link will only affect the steering wheel alignment, meaning both wheels together at one time. Adjusting the tie rod (ends) will affect toe in/out, meaning the relationship of the wheels/tires to each other. I always do my own alignments. I take a small chunk of 2"X4" & drive a long nail through it. Then I lift the wheels (lifting on the axle housing) slightly off the ground & place the nail pretty close to the center of each front tire & barely touching the tread. Spinning the tire will leave a nice thin scribe mark in the tread all the way around the tire. I use this line to measure my toe in/out at the front & rear of the tires. I measure as close as I can (1/2 way up, right at the axle height) and make the front measurement just 1/16" to 1/8" less than the rear measurement. ![]()
Click here to see all of my different albums on Photobucket. Choose any album to see all of my pics! Mean Max is setting up his Jeep shop! Picture history of my progress here. Quote:
There is no situation that cannot be improved with a small but well-placed explosive.
#3 |
It kinda looks like your wheel bearing is shot.
#4 | |
I hate not being able to see pics at work!
#5 |
XJ on 37's
if it isnt the wheel bearing, then you need to close your tie rod, a lot!
i run @1/8" more on the front than rear, when you measure the distance between the wheels at the front adn rear of the rim/tire. check the bearings then tighten up that tie rod! if you run out of adjustment, then you will need to shorten the tie rod itself. if an alignement shop didnt notice that, they need to get a new job!!!!! martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/f12/swap-offically-underway-324622/ Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#6 |
I'm betting on the bearings being shot...I tried adjusting the tie rod with no success.
Thanks for the help guys.
93 renegade |
#7 |
I would check your ball joints aswell.
#8 | |
XJ on 37's
it didnt move it at all? kinda lost me here, but if you think its the bearings, why try to adjust it at all? oh well, check the bearings and go from there. i personally doubt it would be the ball joints, they shouldnt allow it to move toe in and out like it is. if it is leaning in a lot at the top, then yes look at them very closely. in fact, i think a very close look over everything may be in order, as you dont sound too confident in the wheel bearings. better safe than sorry me thinks! ![]() keep us posted! martin
1998 XJ on 37's.JK Rubi axles with chromo shafts and ctm's, 4:1 transfer case, etc etc etc.The Cherylkee.... 1998 Range Rover 4.6 HSE 2000 4.7 4WD WJ with a rebuilt motor. 4.3/700r4/new frame buildup (YJ).... http://www.jeepforum.com/forum/showthread.php?t=324622 Years to gain the hands on experience, and offer it freely. Minutes to gain the knowledge from the internet, and quote it just as freely. Choose wisely! |
#9 |
looks like bad ball joint, i had a ford truck that done that and it was bad ball joints
JEEP NAKED !! |
#10 | |
Is there a better than OEM replacement for the hub bearings? I found alot to choose from on ebay.
93 renegade |
#11 |
Is it bad?
Jim... "That's more fun than watching a hippie get mauled by a bear!" "I love cats, I just can't eat a whole one!" |
#12 |
lost in the woods
Raise the front wheels of the ground. And start looking for play in the frontend. To check the hubs Push and pull at the top and bottom if you feel any movement. Then replace that side or sides. While it's up there id a great time to look at the tie rod ends check both sides look for any movement that isn't happening on the other side.
And one last thought you did use location pins on the springs? |
#13 |
I have not checked them yet. Due to my work/family schedule but I would rather replace them anyway. I forgot to mention 2 wheel studs broke on the driver side and since have replaced all of the studs with ARP's.
I sure miss driving it.
93 renegade |
#14 |
I fixed it!
I had to shorten the tie rod a lot to fix the problem. Thanks a bunch guys!
93 renegade |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
