#211 | |
http://www.youtube.com/watch?v=IcHrkhHXoHo&eurl=&feature=player_embedded
Found this video in another thread from someone, thought i would throw it up here. Guess i cant put a video on here? heres the link
93 yj, 2.5L, 33x12.5, 4inch lift, winch Sacramento Jeepers Group #8 |
#212 |
I had a tank come pull me out |
#213 |
none of these YJ's are stuck.
they're just parked. and they thought it would be a challenge to try to pull out a yj with some other vehicle. this thread should be called "inconveniently parked yj's" |
#214 |
[YT]<object width="480" height="295"><param name="movie" value="http://www.youtube.com/v/IcHrkhHXoHo&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/IcHrkhHXoHo&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="295"></embed></object>[/YT]
that's good stuff right there!!!
STUPID HURTS.......OUCH!@#$ |
#215 |
Actually, I was just doing a routine oil change, you wouldn't believe how much easier it is to get to the drain and the oil filter with out the axles and fenders in the way
1992 YJ Wrangler 4.0L, NV3550, 2.5" suspension lift, 32" BFG M/Ts, lots of other cool stuff RED JEEP CLUB MEMBER #494 |
#216 |
Heres my rig I need a locker destroyed my axle in this
![]() This is me high centered ![]() This was a hole made for ATVS i got out after a while ![]()
89 Jeep Wrangler YJ 4.2L BA-10 Trans NP231 Transfer SYE 35in BFG Mud Terrian Tires Flat Fenders 4in Pro Comp Lift Diamond Plate Rear Corners LED Taillights Warrior Tube Doors KC Daylighters Nates 4X4 Rear Bumper With Swingout Tire Carrier Cobra CB One Working 6x9 Speaker Bikini Top Year Round Lincoln Locker [CENTER][url]http://www.jeepforum.com/forum/showt...=652630&page=5[/url][/CENTER] [B]National Topless Day Feb 3rd 2009[/B] |
#217 |
yeah great place to wheel/ party around here haha
owers of: 91 jeep wrangler sport 2.5L 4" rough country lift, 3 inch body lift, 35x14-15 ground hog tires, smittybilt XRC-8 winch, dana 30 front, ford 8.8 rear welded |
#218 |
![]() I knew it was bad when the guy I was with got out and started laughing. Front dropped in, and stopped dead in silt mud. |
#219 |
![]() buried my swampers under nasty *** mudd |
#220 |
thats a 35 incher on a SOA under there
[COLOR="darkred"][COLOR="blue"]My Daily Driver... [/COLOR]'92 Sahara, 4.0, Auto, A/C, Converted to NIB TF999 Auto 11/08, Relocated Breather, Temp Sender, Transpak, OEM Column Shift, TeraFlex Extreme Short Shaft SYE on '03 TJ 231J, NO T-Case Drop, Tattons 22 1/2", 7" Slip Rear CV Driveshaft, Tattons Front [COLOR="BLACK"]12" Slip[/COLOR] Driveshaft, NO Trackbars, SRS and SOA, OEM rear packs all around, JKS's, 1995 D30, Lockright, JB High Steer, & 3.73 gears, 1995 D35 w/ 30 Spline Ected, Alloy Axles & 3.73 gears, Custom built (by me) Anti Wrap bar using 2 rear tracbars, Welded and Sleeved "Thru Frame" Rear Shock Mounts, Rear Booms, '95 Dual Diaphram Booster and MC upgrade locking 35" Baja Claw Radials, 15x10 Eagle Alloys, 7" Flares, Ramsey Rep 8k, ARB Snorkel, Body Armor Double Hoop Front Bumper, Rocker and Corner Armor, Custom Built (by me) Rear Recovery Bumper/Carrier, Hilift, D-Rings, 30x6 Keeper, CB, Aftermarket Gauges in Gauge Works angled center dash, Trailmax Pro Seats and Center Console, 136 amp 7913 Alternator charging Dual Yellow Tops, 10 KC's = 1300 Watts of Lighting.......... 4480 lbs empty with my softtop, Jim = AKA Ghost183 [COLOR="blue"] Wifes, "once in a whiler"[/COLOR] ALREADY SOLD IT [SIZE="1"]'93 Sahara, 4.0, Auto, A/C, 4" RC kit, (Thanks again Ryan) Standard Shackles, 31x10.5x15 on OEM rims, everything else STOCK.. [/SIZE] [COLOR="Blue"]Tow Vehicle... [/COLOR] '99 Tahoe, soon to be modded[/COLOR] [QUOTE=Mean Max;6554202]BTW I drove the WJ to Dunkin' Donuts today and realized it has [B]GLASS[/B] side windows! What a concept! :D: :cheers2:[/QUOTE] [CENTER][SIZE="2"] [COLOR="Black"]"Important Notice" DUE TO RECENT BUDGET CUTS, STOCK MARKET PERFORMANCE, RISING COST OF ELECTRICITY, GAS AND OIL... THE LIGHT AT THE END OF THE TUNNEL HAS BEEN TURNED OFF.... WE APOLOGIZE FOR THE INCONVENIENCE Regards THE GOVERNMENT[/COLOR][/SIZE][/CENTER] |
#221 | |
#222 |
jeepsurf endorses this post. Most of the time Admin, nightcrew.org 1990 2.5 YJ / 1997 2.5 TJ USAF VET |
#223 |
having the worst day my computer is whack sorry guys for so many of the gay posts
#224 |
#225 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
