Picking up a v8 soon - JeepForum.com
post #1 of 18 Old 07-12-2010, 11:01 AM Thread Starter
93iroZJ
Okay, so I'm going to be picking up a 302 out of a 92 stang and making it carb then hopefully dropping it in my wrangler. Problem is there's a lot of ways I see these swaps being done and if i can I'd like personal input to narrow it down.
I see that specific adapters are made to adapt the engine / trans / t-case but I would like to know which trans is best mated with the bigger v8.
I was going to go the route of a ax-15 with a stage 2 clutch and leave it at that seeing as I wont be wheeling the truck for a while, the np-231 bolts right up, and it'll do okay for street use.
I was even thinking along the lines of keeping the T-5 trans bolted to the 5.0 and maybe running a divorced transfercase seeing as I can't find any adaptors to mate a t-5 with a np231.
My current set up is a 5" lift on stock D30/35 axles running 36" tires with the baby 4 banger BUT with the v8 I'll be upgrading to D44 axles front and rear with 4.56 gears.
If anyone doesn't think the ax-15 will hold to even DD this set-up what transmission can you recommend?
93iroZJ is offline
post #2 of 18 Old 07-12-2010, 11:12 AM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
Keep the fuel injection, it's easy to work with and not expensive to install! The AX-15 should hold up as long as your not beating it to death.
5.7YJ is offline
post #3 of 18 Old 07-12-2010, 12:18 PM Thread Starter
93iroZJ
I'm going carb. The actual question was which way is best to set up the driveline.
93iroZJ is offline
post #4 of 18 Old 07-12-2010, 01:35 PM
DickeyeFab
EFI is the only way to go honestly....your gonna spend some cash converting it over. Either way, if you want a stick I'd put a Ford truck tranny in it...auto? C6...you really need to tell everyone what your intentions are with it...trail? street? etc etc
DickeyeFab is offline
post #5 of 18 Old 07-12-2010, 01:40 PM
ImpactFabWorks
There is a ton of info here
Installing Ford V8 Engines into the Jeep YJ Wrangler
and EFI is the way to go. it is actually easier to install than swapping to a carb
1990 YJ = The Toy/ My Daily Driver
1996 XJ= Wifes Daily Driver
Please fill out your profile, It helps us help you!!!
ImpactFabWorks is offline
post #6 of 18 Old 07-12-2010, 01:41 PM Thread Starter
93iroZJ
clearly people do not know how to read.. it's very nice that you like EFI but I AM GOING CARBED. now back to what I'm asking.
IT WILL BE A DD, IT WILL HAVE A MANUAL TRANS, IT WILL NOT BE IN THE WOODS, IT WILL BE A 302.
LETS TRY AGAIN
93iroZJ is offline
post #7 of 18 Old 07-12-2010, 01:45 PM
Joshhamburger
The ax15 is an okay choice when mated to a ford block, and it actually the only manual transmission that Advanced Adapters recommends when using a ford v8. But if you think that switching to a carb is a good choice both time and cost wise, then you don't really seem to care about what people think. So mate whatever junk yard tranny you can find to it.
Joshhamburger is offline
post #8 of 18 Old 07-12-2010, 01:46 PM
Joshhamburger
Sorry not AA but novak. here is a link to their knowledge base, I would suggest reading it before you do anything.
post #9 of 18 Old 07-12-2010, 01:49 PM
ImpactFabWorks
Maybe you should read, I already posted that
post #10 of 18 Old 07-12-2010, 01:59 PM
DickeyeFab
Personal preferece as everything else....me? I won't buy an adapter for anything....waste of money. I'd start with getting your motor ready to go and then decide. I can tell you this though...your never gonna get a divorced case in there without issues so I would stay away from that.
post #11 of 18 Old 07-12-2010, 02:00 PM
5.7YJ
5.7YJ's Avatar
1987 YJ Wrangler
LETS TRY AGAIN
Yes, we all know how to read and it looks like most people tried to anwser your question. With regard to the carb/FI issue, YOU DON'T HAVE TO YELL, we were only trying to give you our opinions.
5.7YJ is offline
post #12 of 18 Old 07-12-2010, 03:00 PM
DickeyeFab
If ya don't want all the EFI stuff that comes off of it...lemme know, I'm interested...specially if you have the ecm
post #13 of 18 Old 07-12-2010, 03:04 PM
JLITTY
1946 CJ2A
I say just run the ax-15. I Have an injected 351 waiting for a home in my TJ, So Im pretty interested in seeing the outcome of your 302.
JLITTY is offline
post #14 of 18 Old 07-12-2010, 03:08 PM
DickeyeFab
I wouldn't....I have an ax-15 in a jeep I got from a guy that has a 360 dodge in front of it and its half blown up, and the motor is the biggest turd I have ever driven. I have sold 4 ax-15's in the last few months to replace blown up ones in stock jeeps. I'd put a ford tranny behind it and go on. You can get a Zf fairly cheap and keep the overdrive.
post #15 of 18 Old 07-12-2010, 03:32 PM
nitecop
Get you one of the REAL Ford truck trannys NP435, T18, or T19 then go NP205 for a case.
you will never have a tranny or case problem with those.
Jim
USW, OAPSE Union member
99 TJ Sahara 4.0 5-Sp FUV + farm worker
Project f-Xj F150/XJ Ford eXtreme jeep combo
06 6 Speed LJ my daily driver.
Colorado Jeep club memeber #505
nitecop is offline
Picking up an 8.8... T-WOLF2010 YJ Wrangler Technical Forum 11 03-12-2010 10:31 AM
Picking up a 44 JDGreen04TJ TJ Wrangler Technical Forum 6 02-09-2010 07:27 PM
Need help picking an adj. trackbar......... juiceparn JK Wrangler Technical Forum 14 07-02-2008 06:12 AM
picking up an 8.8 b3llo38 YJ Wrangler Technical Forum 24 04-04-2008 12:30 AM
picking up '04 X bajarunner68 TJ Wrangler Technical Forum 2 08-03-2004 08:11 PM
