Picking up an 8.8... - JeepForum.com
post #1 of 12 Old 03-11-2010, 08:56 PM Thread Starter
T-WOLF2010
So i called my local wrecking yard and they told me they had two explorers with 8.8s with 4.10 gears and a "factory locker"(which im assuming is the lsd) im going tomorrow to look at them and possibly pick one up
If i get one should i get anything else while im under there? and what about brake lines how much of the ones on there should i take?
T-WOLF2010 is offline
post #2 of 12 Old 03-12-2010, 02:40 AM Thread Starter
T-WOLF2010
anyone????
post #3 of 12 Old 03-12-2010, 03:54 AM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Since you did not say what your plans are - you have limited what folks may recommend to get.
Typically, rotor to rotor including discs plus everything up to & including where the softline ties into the frame.
The flange adapter could possibly be reused, but if you knew what that was, you'd already know to get it.
Joe Dillard is offline
post #4 of 12 Old 03-12-2010, 04:19 AM
little_Jeep
Not all 8.8 are the same. You want an 8.8 out of a 1996? and newer Ford Exploder. It will have disc brakes. The Limited Slips and 4:10 gears seem to be pretty common in the Exploders.
little_Jeep is offline
post #5 of 12 Old 03-12-2010, 04:27 AM
Joe Dillard
Nope. '95-'01.
'91-'94 have drums.
Plus, Factory limited slips with 4.10 gears are not very common.
post #6 of 12 Old 03-12-2010, 04:33 AM Thread Starter
T-WOLF2010
sorry guys
the ones they have are out of a 97and a 98 and i was gonna put it on my heep after i put the 3.5 inch bds lift on it later this month i was hoping to put it on without having to do an sye and cv driveshaft
can i run the 8.8 with a transfercase drop and the stock driveshaft?
So i can just take the flange adapter off the explorers driveshaft?
post #7 of 12 Old 03-12-2010, 05:29 AM
little_Jeep
Nope. '95-'01.
'91-'94 have drums.
Did you notice the ? after 1996? I never can remember if disc brakes came in 1995 or 1996.
In my area, 4:10, LSD are common as IIRC it is part of the towing package which was a popular option for all the people with boats.
post #8 of 12 Old 03-12-2010, 06:08 AM
boggerjeep
you can buy the correct flange to fit your drive shaft and bolt to the 8.8. i got mine from orielly auto parts.make sure they don't cut your emergency brake cables when they take it out of the explorer.
sell your home. buy a Jeep and a shop. cost about the same to have.
boggerjeep is offline
post #9 of 12 Old 03-12-2010, 06:39 AM
DaveinHouston
Originally Posted by T-WOLF2010 View Post
sorry guys
If you run it with the stock driveshaft the rear axle pinion angle will need to be set parallel with the TC output shaft. If you later install an SYE and CV you'll have to cut the spring perches and reset the pinion angle.
Unless you plan on beating the crap out of your Jeep, or going with 35" or bigger tires your D35 is probably okay. There are a lot of other mods you can do before that and get more bang for your buck.
- 2003 Rubicon - 4" Lift, 35" KM2s, 5.13 gears, winch
- 1968 CJ5 - Dauntless V6, T-86, Dana 18, D27 & D44
- NRA Life Member - Licensed to Carry and Do.
DaveinHouston is offline
post #10 of 12 Old 03-12-2010, 09:40 AM
Joe Dillard
Yep, I noticed it. That's why I added the correct info.
post #11 of 12 Old 03-12-2010, 09:53 AM
Poke
runtime error = 0
Poke's Avatar
2015 YJ Wrangler
sorry guys
I am running this set up. no issues yet.
I got a flange off a unknown year exploder and it fits the 1310 style u-joints.
Get the brakes, lines and hoses. I used the stock YJ ebrake set up and it worked fine. No need for the exploder lines, but there is a way to make them fit. your call.
Originally Posted by ionakana
don't post threads that poke Poke!
Poke is offline
post #12 of 12 Old 03-12-2010, 10:31 AM Thread Starter
T-WOLF2010
thanks guys im going to look at them today
Picking up my JK tomorrow cole925 JK Wrangler Technical Forum 2 03-10-2010 09:12 AM
Picking up a 44 JDGreen04TJ TJ Wrangler Technical Forum 6 02-09-2010 07:27 PM
Picking the right soft top RabidUmpaLumpa JK Wrangler Technical Forum 4 04-01-2009 02:46 PM
picking up an 8.8 b3llo38 YJ Wrangler Technical Forum 24 04-04-2008 12:30 AM
picking up '04 X bajarunner68 TJ Wrangler Technical Forum 2 08-03-2004 08:11 PM
