Peugot to AX15 Conversion - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > YJ Wrangler Technical Forum > Peugot to AX15 Conversion
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 11-13-2006, 02:29 PM   #1
atomicmoose
Just call me Moose
atomicmoose's Avatar
So, I purchased an AX15 from a '92 XJ. My YJ is a '88 and came from the factory with the BA 10/5. Both vehicles have the NP231 T-case.
What am I looking at here? I am still doing my research, but I'd appreciate any tips from those of you that have done the swap. Also of note, it has the internal slave. I have seen that question asked a lot, so I figured I'd clear that up right from the start.
Links, suggestions, experiences, pics....all welcomed!
atomicmoose is offline   Reply With Quote
Unread 11-13-2006, 02:48 PM   #2
jeepinryan
I'm in the same boat, moose. I have an AX-15 and NP231 from a 94 XJ sitting in my garage waiting to go in. I just need some fundage for the other parts Mine also has the internal slave...I may keep it internal just to save some $$, but I'm sure I'll be kicking myself in the *** if I do.
Richmond88YJ did a nice write up a while back on this swap. I know a lot of people have experience with this one, so hopefully you get a bunch of replies
89 YJ Islander, 4.2L I6, Holley 350 CFM 2 Barrel Carb, Transplanted AX-15, 3" BL (going soon), 32x11.50 BFG M/T's on black steelies.
jeepinryan is offline   Reply With Quote
Unread 11-13-2006, 03:42 PM   #3
rejeep
you need a tacse also...
the ba10 has a 21 spline.. the ax15 has a 23 spline..
you coudl swap the imput gears.. but its a royal PITA and the part is almost as much as a good used Tcase.
other than that you need a YJ shifter, and new clutch kit.
You can use your old flywheel, but you need the clucth for a 90 YJ 4.2L ax15.
2012 WK2 SRT8 - 6.4L 470 HP beast
1988 YJ Sahara - 4.2L,AX-15,4:1,D30 w/aussie, 8.8, 4.11, 6"Lift 35"BFG/KMT2
1974 Series 3 109" SW fully restored
1964 CJ5 - V6, currently under full restoration
1949 CJ3a - 6 Volt and stock, staying that way!
rejeep is offline   Reply With Quote
Unread 11-13-2006, 03:47 PM   #4
rejeep
pm sent also
Unread 11-13-2006, 05:27 PM   #5
northjeep
Jeep parking ONLY
northjeep's Avatar
the tcase was not that bad when I swapped the input gear in.
Snap ring plyers and a torque wrench.
The ba10/5 uses 5 bolts to attach to the tcase and there's a plug in the spare hole in the tcase where a stud should be.
Have a look at the np231 rebuild process here:
http://www.jeepforum.com/forum/f12/build-thread-peugeot-ba10-5-nv3550-316455/
-NorthJeep - >> Just Enough Essential Parts
RED Jeep Club member - YJ Club - 258's Unite
northjeep is offline   Reply With Quote
Unread 11-13-2006, 06:27 PM   #6
timatoe
So, if you had say, an 88 YJ with the peugot, and you got an AX-15 and tcase out of say a 90 YJ, would it bolt right up to the engine???? Just wondering my buddies replaced his peugot twice in a year.
timatoe is offline   Reply With Quote
Unread 11-14-2006, 06:33 AM   #7
northjeep
Jeep parking ONLY
northjeep's Avatar
Though I have no personal experience with that exact combo...I'm thinking yes.
But I dont think you would even "need" to swap t-cases but for the input gear, which is not that hard a swap plus while you have the case open you can inspect for wear and or replace other stuff/upgrade chains/learn about your case.
Unread 11-14-2006, 07:58 AM   #8
atomicmoose
Just call me Moose
So, I need:
AX15 - Check
NP2231 with 23 input spline - Check
Clutch for a 90 YJ 4.2L ax15
New shifter
Am I missing anything?
Unread 11-14-2006, 06:53 PM   #9
kloppk
Clutch Slave Cyl...
Tranny mount for the AX-15 to the skid plate...
kloppk is offline   Reply With Quote
Unread 11-14-2006, 08:30 PM   #10
northjeep
Jeep parking ONLY
northjeep's Avatar
new pilot bushing/bearing
paint marker for driveshaft relation to driveline...and flywhee to crank if it comes off.
Impact wrench if the flywheel comes off.
hmmmmmm
Thread locking compound.
ATF, MTF, GREASE GUN
Unread 11-15-2006, 07:58 AM   #11
atomicmoose
Just call me Moose
OK, added them to the list....keep the suggestions coming.
Unread 11-15-2006, 09:59 AM   #12
lah2420
You'll be $$ ahead if you'll convert it to external slave. The time spent to replace the internal in the future will make it worthwhile. You'll need an input bearing retainer, clutch fork, throwout bearing, and master/slave for a 94 tranny. The clutch disc and pressure plate are the same part number from 87 to 99. I would compare the input shaft size on the tranny to the one on the Peugeot. Mine was a direct swap into the pilot bearing for an 87.
lah2420 is online now   Reply With Quote
Unread 11-15-2006, 10:37 AM   #13
jeepinryan
I had heard that you also need to either get shims for the flywheel, or get a new flywheel altogether. I'm not sure about this, but I think that I saw it in a write-up somewhere. Anyone know for sure?
Unread 11-15-2006, 11:21 AM   #14
lah2420
I'm using the flywheel that came on my 87. I haven't had any issues with it.
Unread 11-15-2006, 11:44 AM   #15
atomicmoose
Just call me Moose
I have read to get the flywheel resurfaced, but no shims or replacement.
