Peugeot Transmission completely wasted.... - JeepForum.com
post #1 of 7 Old 06-23-2002, 09:28 PM Thread Starter
katiedog
I have an 87 Wrangler 6cyl carb which just imploded my Peugeot trani. I'm really not interested in putting the same thing back in to my vehicle. What needs to be done to convert over to the AX-15?? I'm not really interested in purchasing a new trani at this time. I'm just looking for some suggestions.
katiedog
katiedog is offline
post #2 of 7 Old 06-25-2002, 01:04 AM
MusicMaverick
MusicMaverick's Avatar
2014 JK Wrangler
They have a diff tranny you can buy that bolts up to the ole' 4.2
Currently: '14 JKU
Past vehicles: '92 YJ, '97 TJ, '10 JK
MusicMaverick is offline
post #3 of 7 Old 06-25-2002, 05:41 PM
dcbeer
I looked at the NV3550 conversion kit lists at Quadratec for $2219.95. It said it was a complete kit but you will still need to replace the input gear on the transfer case. For that price I would think there are better options available. Like a NV4500 if you shoped around and were willing to spend some money.
1988 yj, computer bypass, webber carb and the ever famous BA10/5 transmission (if you have one you know it or will find out).
dcbeer is offline
post #4 of 7 Old 06-25-2002, 07:09 PM
ebhub
I looked into swapping my Puegot out.Basically you have to swap out the transfer case or the input shaft.The Puegot used a different spline count.If you have a 207 transfer case than swap it out too.If you have a 231 transfer case than i would just swap the shaft.
ebhub is offline
post #5 of 7 Old 06-25-2002, 08:06 PM
BigDaddESean
I'm taking out my 4.2 and puegot and putting in a 4.0 and an AX-15. If you decide that u wanna just stick with the puegot, drop me an e-mail. You can take mine off of my hands pretty cheap.
Ebhub, do I gotta change the T-case too now?
89YJ. '97 4.0HO, 4" lift, 33" General Grabbers, Header, no cat, glasspack AR rims
BigDaddESean is offline
post #6 of 7 Old 06-25-2002, 09:37 PM
dcbeer
In a 89 you have a 231 transfer case. You will have to change the input shaft as it is a 21 spline and not a 23. For the ax15 you will need a 23 spline input shaft.
dcbeer is offline
post #7 of 7 Old 06-25-2002, 09:40 PM
dcbeer
My mistake, It is not the input shaft it is the input gear. (the thing the shaft fits into).
dcbeer is offline
Peugeot transmission shifter question Michael Everson YJ Wrangler Technical Forum 2 06-14-2012 09:06 AM
wasted clutch in mud??? help fatjeepguy300 TJ Wrangler Technical Forum 9 08-23-2006 09:47 PM
HELP. my peugeot manual transmission just gave out in my 87 yj RexSt-pierre YJ Wrangler Technical Forum 5 07-28-2005 08:50 PM
Peugeot Transmission problems? UltimatE YJ Wrangler Technical Forum 7 09-27-2004 05:10 PM
That dreaded Peugeot transmission question wr70beh YJ Wrangler Technical Forum 9 12-04-2003 04:56 PM
