permanently locking front axle - JeepForum.com
post #1 of 28 Old 01-09-2011, 01:11 AM Thread Starter
yjman92
today i permanently locked the front axle, by romoving the c clip on the vacuum actuator making the axle always engaged, is there any thing wrong with doing this?
yjman92 is offline
post #2 of 28 Old 01-09-2011, 01:57 AM
CherokeeGT
iam not shure what youve gotta do to lock the axle on yours but..... the newer jeeps dont have axle disconnects at all ... ive owned newer and older styles and theres not difference driving in 2wd at all
CherokeeGT is offline
post #3 of 28 Old 01-09-2011, 03:43 AM
Mark05059
the only thing you may experience is vibration since the front DRIVESHAFT on YJ's are not balanced.
edited to be correct
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #4 of 28 Old 01-09-2011, 05:18 AM
staush
mines locked that way and it doesn't hurt anything other than being hard on gas.
staush is offline
post #5 of 28 Old 01-09-2011, 05:46 AM
kloppk
Originally Posted by Mark05059 View Post
the only thing you may experience is vibration since the front axle on YJ's are not balanced.
Actually it's the front driveshaft that's not balanced on a YJ.
kloppk is offline
post #6 of 28 Old 01-09-2011, 05:56 AM
staush
I've not experienced any vibrations,might just have got lucky though.If you do get a vibration I don't think it costs much to have the drive shaft balanced.For a more reliable fix either install a posi lock or tj axle shafts.There is a link on here somewhere on how to make your own posi lock.
staush is offline
post #7 of 28 Old 01-09-2011, 05:58 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
the only thing you may experience is vibration since the drive shaft on YJ's are not balanced.
Fixed.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #8 of 28 Old 01-09-2011, 07:12 AM
Louie4
Some of the YJ's had a balanced front shaft but not many. I had mine straightened and balanced for $52. If you have more vibration than you want then I would go that route.
Lou
YJOTM July 2012
YJOTM February 2014
Louie4 is offline
post #9 of 28 Old 01-09-2011, 07:19 AM
fatotis
As long as you have the fork holding the collar engaging the axle fixed in position you will be fine. I have used a small screw to keep the fork from sliding or vibrating out of position. I have never experienced any driveshaft vibration but if you do, it is not a big deal to have the driveshaft checked and balanced. Any effect on gas mileage is minimal.
fatotis is offline
post #10 of 28 Old 01-09-2011, 08:46 AM
jaysky
what does that mean when u shift into 4wd both tires will spin? or will they be spinning even in 2wd
jaysky is offline
post #11 of 28 Old 01-09-2011, 09:40 AM
dodger889
Now you did reinstall the c clip right?
Just like this in this write up.
http://www.jeepforum.com/forum/f12/v...ap-way-788543/
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
post #12 of 28 Old 01-09-2011, 10:10 AM
jay-h
It works fine. Even the Chrysler engineer we had here on chat session once said it was ok.
jay-h is offline
post #13 of 28 Old 01-09-2011, 01:38 PM Thread Starter
yjman92
thanks for the input guys i just wanted to make sure it wasnt going to prematurly wear out any parts or damage anything, yes i did the c clip trick as was done in that write up. i have notice a slight vibration around 40 but when i get up to 50 it goes away, but when i put it in 4wd i do get a more noticable vibration, that makes sence about the drivshaft being out of balance, that helps alot. i will have that balanced as Louie4 did. i plan on doing the posi lock eventually. i actually was doing a solid shaft conversion with cv axle shafts and after i went to put the shafts and carrier back in i found out the diff axle seal did not fit so i put it all back together and did this. i will do a writeup on the axle conversion soon
yjman92 is offline
post #14 of 28 Old 01-09-2011, 02:37 PM
jay-h
you might have some looseness your u-joints. Generally an out of balance driveshaft is not load sensitive.
jay-h is offline
post #15 of 28 Old 01-09-2011, 03:59 PM Thread Starter
yjman92
i was thinking the same thing about the u joints, so far it feels good while driving. anybody have any clue why there might be a popping sound, it might be the u joints
yjman92 is offline
Anyone permanently lock their front axle? roblun YJ Wrangler Technical Forum 11 07-29-2014 09:15 PM
Front axle locking question rigger YJ Wrangler Technical Forum 11 04-30-2010 04:14 AM
Could somebody list the plus's and minus's of locking front axle permanently on YJ gary1 YJ Wrangler Technical Forum 9 01-27-2010 06:13 PM
LSD For Front Rubicon Locking Axle my05rubi TJ Wrangler Technical Forum 27 12-22-2008 12:23 PM
Locking front axle and drivability Pointblank TJ Wrangler Technical Forum 8 11-17-2006 07:03 PM
