performance engine upgrades for i4? - JeepForum.com
post #1 of 13 Old 03-03-2013, 09:08 PM Thread Starter
njyj609
Although I'm generally satisfied with the performance of my 4cyl, I would like a bit more. I have found that there is a lack of performance upgrades for this little motor( coil, headers, Cams etc). I've asked my buddies& most say " why bother, just stick in a 6cyl".... but I'd have to swap out the tranny too..... (not in the budget)..... any ideas to get what I can out of the i4?..... it's mostly a DD but I do go play in the mud every chance I get.... re-gear for more speed less torq an option?
njyj609 is offline
post #2 of 13 Old 03-03-2013, 09:10 PM
cstone94
Honestly, your friends are right. The money you spend on rehearing, this includes both front and rear, ~$400, Intake, Cam, etc... You're better off "budget" wise to swap in a 4.0L.
95' YJ - Warn Bumpers/Tire Carrier/Winch - 2.5L - 6" Skyjacker Suspension Lift - 4.10's - Locrite Locker - Dana 35/30 - 35" BFGoodrich KM2's
11' F250 - DD
1982 Toyota Pick-Up - Spray-On Yellow Rhino Lined - Chevrolet 305 H.O. - SM465 - NP208C - All-Pro Off Road 5" Springs - 35x15.50x15 Super Swampers
cstone94 is offline
post #3 of 13 Old 03-04-2013, 01:20 AM
jsawduste
2006 YJ Wrangler
Relocate the IAT and the crank sensor. I`ve covered both in past posts.
jsawduste is offline
post #4 of 13 Old 03-04-2013, 06:55 AM
Que89YJ
The older 2.5L like ours is a little more difficult to modify cheap because of the throttle body injection. Rad fan, regear, + Jsawduste recommendations.
Que89YJ is offline
post #5 of 13 Old 03-04-2013, 07:40 AM
grandboost98
Good thinking. You got me interested and so I just did a search and came up with some old threads that your pics were no longer working. Good info though
I did read that you can use a TJs without relocating it to the airbox and it will trick the computer to thinking its 60* colder than what it really is. Dont know exactly how true that is but seems easier than relocating it
04 Grand Cherokee Overland
72 Chevy Nova-in progress
grandboost98 is offline
post #6 of 13 Old 03-04-2013, 08:00 AM
Fuddmaster
The bigger throttle body helps, from a 4.0l. I've heard bigger injectors but never looked into it
Fuddmaster is offline
post #7 of 13 Old 03-04-2013, 06:38 PM Thread Starter
njyj609
Thanks all... I will search your earlier threads jsawduste...... que89yj; Radfan? As in radiator fan? Would you mind explaining what you are suggesting? & I will do some research on the throttlebody, that sounds like a great idea.
njyj609 is offline
post #8 of 13 Old 03-04-2013, 07:17 PM
baritone_mike
Yes he is talking about the radiator fan.
An electric fan from a Ford Taurus is enough to keep the Jeep cool. It will free up the power that the big clutch fan on the front of your engine uses. You can also wire it to turn on and off when you want it to, so you can switch it off before a water crossing or flip it on before a big mountain pass to keep it cool.
http://www.jeepforum.com/forum/f12/e...rk-vii-506679/
*I have not done this swap*
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
baritone_mike is offline
post #9 of 13 Old 03-04-2013, 07:30 PM
Que89YJ
Can't do the throttle body on our 2.5 only the 91 mpfi and later.
Fault codes:
Mean Max pics of everything:
No Start:
Que89YJ is offline
post #10 of 13 Old 03-04-2013, 08:03 PM
Chrisnvegas
Chrisnvegas's Avatar
There are performance kits available for the 2.5 but are kind of pricey. They claim 45% more HP and 55% more torque for @ $1700.00
I'm surprised Summit Racing doesn't sell cams or pistons for this motor.
http://www.shop.505performance.com/c...?categoryId=40
Ban computer updates, auto-play video and music without real instruments.
Chrisnvegas is offline
post #11 of 13 Old 03-04-2013, 08:04 PM Thread Starter
njyj609
I see... I just went through older posts and I think I get it..... the electric fan, tbi swap & sensor relocation seem to be agreed on as the only meaningful mods for the 4 cyl . The little torqmonster just doesn't have the horses to give.... & que89yj; very disapointed that I can't do the tbiswap ..... I must admit tho, I have a nice dodge ram & still take the Jeep instead.... ha..... thanks to you all!
njyj609 is offline
post #12 of 13 Old 03-04-2013, 08:06 PM Thread Starter
njyj609
I can't believe a performance coil isn't available tho...... really?
njyj609 is offline
post #13 of 13 Old 03-04-2013, 09:19 PM
Que89YJ
4 bangerjp.com and read.
You have tbi you can't swap the tb.
Fault codes:
No Start:
Que89YJ is offline
