Performance camshaft install - JeepForum.com
post #1 of 13 Old 01-23-2006, 04:16 PM Thread Starter
jeepboy21
I have had the cam sitting in the garage for about 8 months now and i cant wait, i want it in. I have a crappy hanyes manual that doesnt help so i am looking for a good writeup. also any tips, tricks or things i need to watch our for would be greatly appreciated.
93 YJ 2.5L 5 spd,D35 lockrite,D30 powertrax,4.0L TB,4.0L TB Spacer, Warrior Products rear bumper,Bigrocks offroad front stinger bumper,2.5" ghetto lift,skyjacker hydro's,arb snorkle,31x11.5 super swamper truxus A/T STS on cragar soft 8s,31x10.5 wildcat ext studded on ar 767,hella 500's 1 set fog and 1 set driving,sway bar disco's, extended brake lines,yellow top,CB, body damage to prove I wheel.
jeepboy21 is offline
post #2 of 13 Old 01-23-2006, 04:50 PM
myjeepsux420
Do you only have the cam, or did it come with lifters, push rods and rockers? You know that you have to remove the head, front timing cover and well as the radiator and front grill. You might want to pull the entire engine and have new cam bearings installed. Really depends on how many miles you have on the engine.
1995 YJ Stroked 4.5L I-6 Headders, high flow cat. and exhaust Big Bore Throttle Body, Cold Air intake
Jet Chip Stage 2 plus thermostat
3 1/2 inch lift with 33x12.50 tires
Posi Lock front diff and Ford 8.8
myjeepsux420 is offline
post #3 of 13 Old 01-23-2006, 05:10 PM
jipjip
jipjip's Avatar
you dont necessarily need to pull the engine out to replace the cam bearings. remember! yj's front grilles and radiators come right out easily, and give you access to the entire front of the engine, making cam bearing removal a cinch.
you dont need to remove the head either. just the front timing cover, timing chain, and cam/crank sprockets. just make sure the timing chain is lined up properly after the install. it would be a bad thing to bend a bunch of valves after all that work
he's right about pushrods,lifters,and rockers too. if your replacing the cam, you should rid yourself of those tires lifters, worn pushrods and rockers, for some new ones, possibly w/ a roller setup for less friction,and higher revving capabilities. might as well while your in there
95 yj sahara green w/ spice hard and soft top, bikini top,full steel doors, and 2 piece bestop soft doors,tnt customs front tube fenders w/ 6" flare,warn gas tank skid, skidrow oil pan skid,4.0HO,rear 31 spline 8.8 w/ disc brakes,4.10's and lsd,front HP d30 w/ 4.10's and aussie front locker,ax15,np231j w/ jb conversions ss sye, tom woods custom cv d/s,RE 4.5xd,35" toyo open country m/t's, 1" daystar body lift, warn 9.5ti
jipjip is offline
post #4 of 13 Old 01-23-2006, 09:26 PM
Christopher_2
Did you put it in yet? Did you notice a difference in performance?
Christopher_2 is offline
post #5 of 13 Old 01-24-2006, 08:15 AM
MLJeeper
MLJeeper's Avatar
The cam bearings are not going to be in any worse condition than the bottom end of the motor. If theres that much wear put it back together and gather parts for a rebuild and build a spare 2.5 to swap in later. That cam probably cost half of what a basic rebuild kit costs for that motor.
Check that the push rods are true and clear, if so you can use them again. but they shouldnt be too expensive and its not a bad idea to replace them. The cam should have come with new lifters. If not you must replace them with new ones. As for new rockers, you dont "have" to replace them, but you will not get the full lift of your cam with the worn rockers. And im assuming this is common sense but no ones said it. Always put on a new timing chain.
Your limited slip differential sucks.
Any video of the sound?
MLJeeper is offline
post #6 of 13 Old 01-24-2006, 03:35 PM
myjeepsux420
If you remove the cam with the lifters still in, won't they fall in the way of the cam when your trying to re-install?
post #7 of 13 Old 01-24-2006, 04:10 PM
jipjip
jipjip's Avatar
not true. if he's gonna replace the camshaft w/ a new one, the clearances HAVE to be perfect, or the new cam wont last 5mins. if the bearings are work (which they usually are), this will cause excessive clearance, but the stock cam shaft has worn too, and it wares w/ the bearings. a new camshaft is going to have different clearances to the stock piece, and it's not even broken in yet. when a new camshaft goes into the engine, you have to perform a 'break in procedure' which consists of starting the engine, and holding it at 2,000rpm for 10mins straight. this period decides if the cam lives or dies... w/ the old set of bearings, the oil doesnt feed the camshaft properly, and during this procedure, will damage the cam lobes beyond repair.
do yourself a favor, and get new bearings.
jipjip is offline
post #8 of 13 Old 01-24-2006, 04:46 PM
myjeepsux420
Pull the engine, install new cam bearings, lifters, push rods and rockers. You might as well rebuild the entire engine while your at it.
post #9 of 13 Old 01-24-2006, 05:53 PM
Yule16MET
Yule16MET's Avatar
Anybody have links to engine rebiuld kits/camshafts? For a 4.2?
I dream of the jeep, drive the chevy and roush pays for it all
1990 YJ lerado,Soa,2.5R.E.springs,8.8,4.88'sPSC trail cage&rocker nockers w/sliderbars,home made bumpers, 35"boggers,sye, tomwoodsds, revolvers, red & yellow optima, bushwackers,corbeua ss seats,mc2100,juicebox, 3core rad., b&mshifter and highlift,5point harnesses,wheel spacers,9000lb mile marker,ssdash kit,no sway bar, no trackbar, walmart lights,clinometer, XJ passenger shaft, axle tube seals, M.O.R.E track bar
And a Monster Yellow CJ5
40x17's 12"lift full cage
Blackjeepclub #16
Armyjeepclub #16-#1
yellowjeepclub #BIG16
Yule16MET is offline
post #10 of 13 Old 01-25-2006, 08:46 AM
00Vert
[QUOTE=jipjip]not true. if he's gonna replace the camshaft w/ a new one, the clearances HAVE to be perfect, or the new cam wont last 5mins. if the bearings are work (which they usually are), this will cause excessive clearance (Quote)
This is so NOT true. People swap cams all the time and never have a problem with cam bearing clearance. Cam bearings are a std size and don't vary. If your cam bearings are worn to begin with, this won't help them and they should be replaced. If you don't damage them when you R&R the cam, they will be fine. Even if they were worn, the cam doesn't destroy itself. The cam doesn't even get its oil from the cam bearings, it is splash fed. So many myths out there!
00Vert is offline
post #11 of 13 Old 01-25-2006, 06:06 PM
jipjip
jipjip's Avatar
so your telling me that an engine w/ that many miles on is going to have perfectly good bearings i dont think so. what would you rather do, save some money now, and possibly kill the cam within minutes!!!!, or spend the money now and do it the right way. i would hate to see that camshaft die after spending all that money on it
jipjip is offline
post #12 of 13 Old 06-11-2006, 04:58 PM
yj kid
How do you hold the lifters out of the way when you install the new cam without taking the head off?
yj kid is offline
post #13 of 13 Old 06-11-2006, 05:02 PM
yj kid
Biggest thing when swapping cams is clearances. Check fully compressed springs and make sure the valve stem keepers don't interfere with the guides. And check you're piston to valve clearance.
yj kid is offline
Bad camshaft in some 04 TJs PackMan TJ Wrangler Technical Forum 4 01-22-2012 12:34 PM
Hawk Performance HPS High Performance Street Disc Brake Pads? NW Jeep TJ Wrangler Technical Forum 54 11-02-2011 09:54 PM
1" Performance Accessories Body Lift Install blazer190 TJ Wrangler Technical Forum 4 07-13-2008 04:48 PM
Performance Accessories BL Install ? y-hike TJ Wrangler Technical Forum 7 12-17-2004 06:15 AM
4.2l performance camshaft options.... Radioflyer YJ Wrangler Technical Forum 2 09-02-2002 11:32 PM
