Performance for a 90 yj - JeepForum.com
post #1 of 22 Old 06-29-2013, 11:32 AM Thread Starter
moeller26
Does anyone have any suggestions to get more power in my YJ it's a 1990
moeller26 is offline
post #2 of 22 Old 06-29-2013, 11:38 AM
blackjeep05
Not a whole lot you can do but, is it a four banger or a 258 six? If its a 258 six you can put a head on a 4.0L on it to pick up about 40 horsepower. You will have to make some modifications to do it but, its do able. You can also do fuel injection for either engine but, it can be pricey. What is your current set up? Auto? Manuel? Tires,lift?
Soccer six in the mix.
blackjeep05 is offline
post #3 of 22 Old 06-29-2013, 11:41 AM
dancytron
Fill out your profile.
Is the issue that it isn't running right or that the stock performance isn't good enough for you?
dancytron is offline
post #4 of 22 Old 06-29-2013, 11:53 AM Thread Starter
moeller26
Stock isn't good enough. It's straight six 4.0 4in suspension lift with 35's
post #5 of 22 Old 06-29-2013, 11:55 AM
crackedcornish
speed is just a question of money....how fast do you want to go?
http://www.novak-adapt.com/knowledge/yj_87_95_swap.htm
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline
post #6 of 22 Old 06-29-2013, 12:04 PM Thread Starter
moeller26
Around 65 but I want to be able to make it up hills with power too. I can get to about 55
post #7 of 22 Old 06-29-2013, 12:12 PM
blackjeep05
what gears you running? 35s are big tires and to be able to run 55 up a hill is not bad.
post #8 of 22 Old 06-29-2013, 12:15 PM Thread Starter
moeller26
I don't know the gears. And I wish I coul go 50 up a hill on a good day maybe 30
post #9 of 22 Old 06-29-2013, 12:22 PM
blackjeep05
well check your gears because if your not geared right everything else is mute.
post #10 of 22 Old 06-29-2013, 12:23 PM
blackjeep05
With 35s I would say 4.88s or so but, depends alot on if you have a stick or auto.
post #11 of 22 Old 06-29-2013, 12:39 PM
wendell
1987 YJ Wrangler
In 1990 it should be a 258 straight 6 unless a 4.0 has been swapped in. Lets say it is a carbed 258 and I'll tell you what I did with my 258 for more power. I installed a 470 holley TA 4 barrel carb, offy dual plane intake manifold, roller rockers, comp cam, higher compression pistons, ported head, header, dui distributor and MSD. My 258 will scream, it really bumped the power to well over 200 hp. The 4.0 head works best on a 258 if you go FI. I found a ported 258 head works better with a carb as far as making more power with my other mods. The 258 is capable of making great hp and gobs of low end torque with throwing a few parts at it.
1987 wrangler, 258 I-6, 5-speed.
2007 liberty sport 4X4, automatic
2009 ford ranger 4x4 FX4 OFF/ROAD, 5-speed
wendell is offline
post #12 of 22 Old 06-29-2013, 12:40 PM
Tom95YJ
[] Eye'd Jeep Connoisseur
Tom95YJ's Avatar
4.88 gears , 4.0 Head. Fuel injection and a cam you'll be good
Sent from AutoGuide.com App
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
post #13 of 22 Old 06-29-2013, 12:50 PM
roadyrob
1987 YJ Wrangler
with 35"s your biggest problem is the gears but wendell gave you good advice on how to get more power from the 4.2. fix the gears first.
Do everything with a positive attitude, it won't always work but you'll piss enough people off to make it worthwhile.
the voices aren't real but they sure have good ideas.
roadyrob is offline
post #14 of 22 Old 06-29-2013, 02:04 PM Thread Starter
moeller26
How much will this cost? I have time to work ok it but there is only so much money
post #15 of 22 Old 06-29-2013, 02:24 PM
Tom95YJ
Tom95YJ's Avatar
Gears and carriers roughly 500-600 then the going rate for labor is 250-300 an axle
'89 YJ The Smurf
'99 XJ Black Betty
Tom95YJ is offline
